Author Topic: Torque specs for valve adjustment.  (Read 1055 times)
Abner_Bjorn
  • 5280 Scooter Group Rides on FB
« on: December 29, 2013, 06:47:04 PM »
Good morning.
Can anyone provide me with the torque specs for the valve cover and adjuster nuts on my Like 200?
Thank you!
Less chit chat, more riding.
tclhb
Re: Torque specs for valve adjustment.
« Reply #1 on: December 29, 2013, 10:38:14 PM »
I believe the valve cover bolts are 8.9 Nm. That's from memory
Tom. Huntington Beach, California
« Reply #2 on: December 30, 2013, 02:03:18 AM »
when working with the adjuster nuts and screws we are working with steel....so a gentle/firm but not crazy tightening should be fine.
SEE this last sentence above - this is a very good idea = it double checks the adjustment you just did. Rotate the engine and check again!
However the valve cover is softer alloy so - easy does it!
Hope this helps.www.cyclepedia.com carries the LIKE service manual (above pix from there)Stig
« Last Edit: December 30, 2013, 02:08:32 AM by Stig »
Abner_Bjorn
« Reply #3 on: December 30, 2013, 02:56:17 AM »
Thanks to both of you.
