Author Topic: S9 Dyeing  (Read 1102 times)
joebro
S9 Dyeing
« on: January 15, 2014, 02:28:12 PM »
So my S9 LC was running great, now my engines missing at low rpm (this may be unrelated) and its dyes without throttle. When i first start it it runs fine but when i rev to high rpm (around 7500 rpm) and let off it either bounces between 2000 and 3000 rpm then just dies or it gets stuck a 4000 rpm with no throttle. My S9 is all stock and the only mod is my boss drive is derestricted and battery was change.
« Last Edit: March 10, 2014, 02:35:54 AM by joebro »
You only live once but if you live right once is all you need.
ophelia
Re: Urgently Needing Help S9 Dyeing
« Reply #1 on: January 15, 2014, 04:55:15 PM »
How much mileage do you have on your Super 9?
Did you ride it regularly?
I am thinking you have an air leak or a plugged carburetor. A lean mixture (i.e. Not enough gas through intake) may be causing your engine to surge and stay at high rpms.
2011 Kymco Downtown 300i
joebro
« Reply #2 on: January 16, 2014, 02:17:07 PM »
It has little of 4500 miles on it and yes it is my daily driver but i have only been the owner for about a month. I considered it may be something with the carb, but I am curious if it may be my CDI.
ophelia
« Reply #3 on: January 17, 2014, 06:33:00 PM »
When was the last time the scooter was serviced? Maybe you are simply due for a tune-up and carburetor cleaning.
joebro
« Reply #4 on: January 18, 2014, 04:31:31 AM »
I have no idea seeing as i am the second owner, but I am gonna have the carb cleaned and tuned soon. Ill post my results hopefully that will help.
0BARK4322
« Reply #5 on: January 18, 2014, 01:39:24 PM »
THAT SHOULD DO IT
ALL STOCK
joebro
Re: S9 Dyeing
« Reply #6 on: March 10, 2014, 02:37:47 AM »
Well shes clean but not tuned yet. Seems to have fixed my issues with bogging and hard starts, but it is still dyeing without throttle. Hopefully a tune up will fix that!  :)
