Author Topic: Rejetting necessary after third party exhaust?  (Read 8503 times)
guile
« on: January 19, 2014, 04:19:17 PM »
Is it necessary to rejet a 500 Xciting carb (2006) with a third party exhaust?
sissy mary
Re: Rejetting necessary after third party exhaust?
« Reply #1 on: January 19, 2014, 11:33:05 PM »
Yes, if it pops on deceleration? I would go up 1-2 main jet sizes at most. Leave everything else alone.  Go 2 up if you put in a K&N style air filter like the DNA filter that is sold on ebay. :-*
guile
« Reply #2 on: January 20, 2014, 07:17:42 AM »
Thanks Sissy. The exhaust is not yet installed. Hopefully it doesn't pop!
guile
« Reply #3 on: February 12, 2014, 01:56:55 PM »
I installed the exhaust the other day. Great fun! Definately a bit more hp.
But it pops quite heavily when decelerating...
Sissy, could you direct me to the correct jets (on Ebay for instance)?
I have the stock airfilter installed.
sissy mary
« Reply #4 on: February 12, 2014, 08:25:59 PM »
Main jet sizes depend on what country your bike was sent to? Europe is different from USA etc. It is a standard screw in jet. Remove and buy the next 2 sizes up.  :-*
guile
« Reply #5 on: February 14, 2014, 09:36:50 AM »
Mine is European. Anyone knows what size(s) jet I need to buy?
sissy mary
« Reply #6 on: February 14, 2014, 12:24:39 PM »
Almost all shops should stock them. Call a shop that sells them, remove your jet and buy 1 & or 2 sizes up. It sounds like u should go up 2, or even more? :-*
guile
« Reply #7 on: February 28, 2014, 10:11:43 AM »
What mm-size is standard and to what size does it need to be changed?
« Last Edit: February 28, 2014, 10:30:13 AM by guile »
sissy mary
« Reply #8 on: February 28, 2014, 12:09:09 PM »
If a kymco shop can not tell you? Then just pull it out and buy one about 2 sizes up. If it still pop's, go up 1 more until it stops. :-*
Porkie
« Reply #9 on: February 28, 2014, 01:46:45 PM »
You should also raise the 'needle' in the slide that affects 'mid-range.' "Raise=rich, Lower=lean."
Doing both the main jets and the slide is standard operating procedure for tuners.
You may be able to just go to the MFG's web-site and then either email customer service or call them and just ask them what size they recommend.
Sam:)
2014 Polaris Ranger 800 crew cab 4x4
2012 Honda Goldwing Blue
2013 Kymco Xciting RI ABS in gold/ orange
2005 Suzuki Burgman 650 blue metallic
KF6GUW Amateur Extra
guile
« Reply #10 on: February 28, 2014, 04:25:22 PM »
Thanks for the advice!
guile
« Reply #11 on: March 10, 2014, 06:08:01 PM »
Guys, I really need to know what the standard jet size  is of a Xciting (2006, carb). There is no Kymco in Holland
guile
« Reply #12 on: March 12, 2014, 01:05:34 PM »
FYI
standard jet size is supposed to be 108. I will get the jets as soon as possible and report back.
« Last Edit: March 12, 2014, 01:14:43 PM by guile »
guile
« Reply #13 on: March 29, 2014, 12:57:50 PM »
Got the carb adjusted by a mechanic a couple of days ago.
It won't start now >:(
He said he adjusted the 'C0 screw'(?). It pops (sometimes even heavily!) when starting, but it won't start.
Can someone shine a light on this so I can fix it myself?
sissy mary
« Reply #14 on: March 30, 2014, 12:02:23 PM »
He messed it up! Tell him to fix it FREE. At least have him set it back to stock. I never have a mechanic adjust my carbs. They only make it worse. Its easy to change a jet or raise a needle. Idiot should have left everything alone & just put in next size up main jet. I can't tell u what to do as I don't know what it is he really did or didn't do? :-*
