Poll
what is the correct number of turns from seated to tune the jet on the agility 50?
idk
1 (100%)
idk
0 (0%)
idk
0 (0%)
Total Members Voted: 1
Author Topic: Agility 50 carb adjustment  (Read 6426 times)
amsoilguy
« on: August 24, 2009, 08:05:33 AM »
What is the proper adjustment for the carb on the agility 50 any info is greatly appreciated!!!
Re: Agility 50 carb adjustment
« Reply #1 on: August 24, 2009, 10:29:47 AM »
...unless youi're having problems keeping your scoot running at idle...there is really no worries...since carburetor adjustments only effect your engine at idle, and just off idle...1.5-2 turns counter-clockwise is about the standard...
peace
Shaka
« Reply #2 on: August 25, 2009, 12:03:08 AM »
I would agree.  I have found the easiest way to do it is to set both the idle and mixture screws at 2 turns out.  Then adjust the idle screw first.  Then once you have the idle set, fine tune the mix so the 0-1/4 throttle snap is nice and responsive.
« Reply #3 on: August 26, 2009, 10:34:45 AM »
..sweet...I was going about it the right way then...thanx shaka!
