Poll
will changing the jet out to a number 82 or better improve performance on a mostly stock agility?
82
0 (0%)
8?
0 (0%)
Total Members Voted: 0
Author Topic: More agility 50 carb questions  (Read 3331 times)
amsoilguy
« on: August 24, 2009, 05:05:17 PM »
Will the stock 50cc engine appreciate the more fuel it would be recieving from the larger jet with the cdi box hacked and the restrictor washer taken off the flywheel?? what would be the best jet size for my application? Everyone's help on this forum is greatly appreciated I didn't know there were so many die hard perfomance enthusiasts on scooters willing to help the new guy out.
« Last Edit: August 24, 2009, 05:06:54 PM by amsoilguy »
Re: More agility 50 carb questions
« Reply #1 on: August 24, 2009, 05:08:57 PM »
...generally, an 85 jet should work nicely..."Stock" jet is an 80...I've read some prefer an 82, but my dealer suggested the 85...
peace
« Last Edit: August 24, 2009, 05:19:46 PM by wordslinger »
« Reply #2 on: August 24, 2009, 09:58:05 PM »
I agree w/ slinger. #82 would be fine w/ a stock air box,and for another $10.00 us you can get a k&n type filter, and run the #85.  Poss. raise the needle 1 notch
Kenho21
« Reply #3 on: August 25, 2009, 06:57:05 PM »
I put the #85 in with stock air box, bad idea, I replaced the stock jet soon after.With a UNI filter or something like that would probly be nice though.I have a question also. What does raising the needle do and how do I raise it, I know where its at and used a washer to do it but took it off soon after also. Is there a different method to do this.
Ken
Shaka
« Reply #4 on: August 25, 2009, 08:49:17 PM »
The needle controls the fuel delivery from about 1/4 -3/4 throttle.  From 0-1/4 throttle the idle jet controls the fuel, and from 3/4-full the main jet controls the fuel.  Raising the needle will increase the fuel delivered in that throttle range.  Lowering will decrease.  I'm not sure about your particular carb, but my Arreche has 3 different positions to change the height.  There are small grooves near the top of the needle that a clip snaps into to change the height.  There are also different needles available with different tapers to fine tune even further.  Hope this helps.  Ask for clarification if needed.
« Reply #5 on: August 26, 2009, 03:18:52 AM »
Rock on shaka!
« Reply #6 on: August 28, 2009, 08:42:04 PM »
..my stock carb on my A-50 has no needle adjustments...dang...
« Reply #7 on: August 28, 2009, 09:53:39 PM »
Like the fella a few posts earlier said, you can use a tiny washer to raise the needle. I have used little O-rings in the past. Or you could MIC. out a few replacements, But it all seems like a lot of trouble if things are working fairly well. Seems like just when you get it ALL RIGHT, the gremlins come in and change something.
« Reply #8 on: August 29, 2009, 09:15:14 PM »
yeah, i just need an 85 jet..
..and i'll be satisfied with what I gots...
..this is my only legal ride right now...
Kenho21
« Reply #9 on: August 29, 2009, 09:58:12 PM »
did you get a hold of scooter therapy? thats where I got my 85 jet
« Reply #10 on: August 29, 2009, 10:00:05 PM »
So far, i've just been looking local..but thanx for the tip!!
Kenho21
« Reply #11 on: August 29, 2009, 10:01:54 PM »
I would give them a call they are very helpful for me.
Scooter therapy # (608) 255 1520
« Reply #12 on: August 29, 2009, 10:03:35 PM »
..awesome!..
I saved that number...
« Reply #13 on: August 30, 2009, 11:56:01 PM »
Also for tough to find jets, I posted earlier you can use "PIN DRILLS" to open up what you have. You can get a set for around $25.00 U.S., and w/ the little "VISE" they come with it only takes finger presure to open the brass jet.
« Reply #14 on: August 30, 2009, 11:57:30 PM »
..hey...cool..where do I get them, and do you know what the ID of an 85 jet should be??
