Did you miss your
activation email
Scooters - Big Bore
Xciting 500
Multifunction meter (Dashboard)
Topic: Multifunction meter (Dashboard) (Read 912 times)
Porkie
Sr. Member
January 27, 2014, 01:54:57 PM »
The indicator needles of the multifunction meter are supposed to sweep from zero to their maximum reading then back to zero when the ignition switch is turned on (pg 18 owners manual) but my 500 doesn't do so?
? The bike runs perfect and everything works but what is going on? I've looked in the owners manual and can't find a word about how to fix the problem, if indeed it is a problem! Help please:)
Sam:)
2014 Polaris Ranger 800 crew cab 4x4
2012 Honda Goldwing Blue
2013 Kymco Xciting RI ABS in gold/ orange
2005 Suzuki Burgman 650 blue metallic
KF6GUW Amateur Extra
Cortez
Re: Multifunction meter (Dashboard)
January 27, 2014, 02:21:52 PM »
First gen Xcitings here didn't do the sweep, and their manuals are notorious for mistakes
and copy/pasting from other bikes.
I've been translating them from English to Croatian for the past 2 years, so, don't ask me
how I know.
I'd ignore it.
'08 FZ6n S2 ABS
desliderman
Full Member
February 06, 2014, 05:27:57 PM »
I have a 2012RI with ABS. I went to my dealer for the very same reason. I had owned several scoots in the past, and not just Kymcos. In all cases the needles swept.
I was told by my dealer not to worry about it.
That was some 16000 miles ago.
Don in KC.
Porkie
Sr. Member
Reply #3 on:
February 06, 2014, 10:21:29 PM »
Thanks for the replies, I appreciate it.
I'm going to put a charging pig tail on the battery soon and supposedly if you disconnect the negative cable and turn the switch to the start position and then touch the negative cable to the negative terminal it resets everything.
Sam:)
Back
