Author Topic: Tuners eyes only  (Read 3194 times)
Kenho21
Tuners eyes only
« on: August 25, 2009, 07:23:30 PM »
After my 85cc kit UNI foam filter and bigger jet what mod should I do next for biggest or best performance?
Re: Tuners eyes only
« Reply #1 on: August 26, 2009, 03:42:52 AM »
variator-clutch-pipe-tires-NOX, Oh yeah...BRAKES!!!
Kenho21
« Reply #2 on: August 26, 2009, 03:21:46 PM »
I already got NCY exhaust, clutch and variator was my next idea also but what about carb?
« Reply #3 on: August 26, 2009, 08:53:06 PM »
You should go to a larger cfm carb. to accomidate the extra flow through your cylinder. the manufacturer of your kit could tell you what size (mm), I would carefully try to match their recomendation, at least for size, and try to find a model that is easy to tune/ swap parts. Also consider carbon graphite reeds.They will open easier, and close quicker compared to stainless. Your cdi may have a rev limiter depending on where the scoot was marketed for, this is a good couple of mph (top end) also the largest tire you can fit will give a few more. A true high performance Ign. coil will help ignite it all quickly, and completely. Jiangwayne.com has some realy trick lite weight wheels. Other than that, good fluids and constant maintenence.
Shaka
« Reply #4 on: August 26, 2009, 10:51:06 PM »
Well said Zombie!
« Reply #5 on: August 27, 2009, 02:56:18 AM »
I look foward to seeing what everyone here is doing/ saying/ passing along,more than most of the thing's that happen in my average day. Just happy to give something back w/out all the smart asses you get on some sites. KUDOS to turnbuckle, and ALL who keep it real.
« Reply #6 on: August 27, 2009, 12:34:24 PM »
..I second that!!!
Kenho21
« Reply #7 on: August 29, 2009, 07:09:31 PM »
Wow, thanks for all the info. What are the reeds?
ken
Shaka
« Reply #8 on: August 29, 2009, 09:58:40 PM »
The reeds are kinda like the intake valves.  They are between the the intake manifold and the engine.  They are like one way valves to let the fuel/air mix into the engine.  They let air mix in on the intake stroke, piston moving down; and close off so air mix cannot escape on the compression stroke, piston moving up.  Hopefully that makes sense.
Kenho21
« Reply #9 on: August 29, 2009, 10:00:39 PM »
have you seen any online for the 139qmb? I don't remember seeing any.
Shaka
« Reply #10 on: August 29, 2009, 10:02:43 PM »
Only 2-stroke motors use them.
