Author Topic: Locked Throttle  (Read 964 times)
H'er
Locked Throttle
« on: January 28, 2014, 02:49:32 AM »
When going to start my one year old Agility 50 I find the throttle stuck/locked in the closed position, i.e. cant turn the throttle.  Everything has worked fine for 11 months, then this started, though only occasionally.  Thoughts?
MaryK
Re: Locked Throttle
« Reply #1 on: January 28, 2014, 02:43:07 PM »
Probably a rust problem.  3 places to look:
(1) the throttle cable;  It has an outer sheath and an inner cable that moves the throttle, so oil the inner cable.
(2) The throttle sleeve (the piece that you grab and rotate).  It can have rust from the handlebar under it.  Remove and clean
(3) the throttle at the carb.  The easiest to lubricate. Use a spray oil.
scoot safely,
New Rider in 2010
2009 GrandVista 250
Eherim
Re: Locked Throttle
« Reply #2 on: February 04, 2014, 06:09:46 PM »
Does anyone know of a good how-to-guide showing newbies how to do this? Where to find it, and so on?
Give way to trains.
tortoise
Re: Locked Throttle
« Reply #3 on: February 04, 2014, 06:17:58 PM »
Eherim
Re: Locked Throttle
« Reply #4 on: February 04, 2014, 06:38:27 PM »
RollingWrench videos.
Q: What is ten times ten?
A: It's spelled "V-K-L-O-P".
Give way to trains.
Re: Locked Throttle
« Reply #5 on: February 04, 2014, 08:44:37 PM »
I totally don't get that one, Eherim. Please draw a picture......
Eherim
Re: Locked Throttle
« Reply #6 on: February 06, 2014, 01:24:39 PM »
:-) OK, it was just, that I felt, that the question asked was answered with something that didn't have a whole lot to do with the question.
Give way to trains.
