Author Topic: 125 cc Redlining  (Read 1020 times)
motoman
125 cc Redlining
« on: February 06, 2014, 10:10:11 AM »
Hi, I have a Kymco Pulsar LX 125 cc motorcycle. I have noticed at around 50 mph in top gear (5th) it's already beginning to redline. According to Kymco the bike  has a top speed of around 60-65 mph in top gear. So, surely it shouldn't start to redline until around 60-65 mph in top gear. Is anyone able to comment on this please. ::)
ophelia
Re: 125 cc Redlining
« Reply #1 on: February 06, 2014, 09:51:54 PM »
Silly question first, are you really in top gear? I know it sounds silly, but it has happened before where people feel they are in top gear but there's actually one ratio left to go. I had a CBR with a very firm shift lever once I got into 5th, but it surprisingly shifted past that once I squeezed the clutch and lifted my toe anyways.
Does the Pulsar have a tachometer? Are you able to keep revving beyond the indicated redline? I know the Quannon motorcycle has a higher rev limiter than the redline on the tachometer face. The gauges start the redline at 8000 when the bike is advertised at 9000 rpm.
« Last Edit: February 06, 2014, 09:53:40 PM by thesurgeonistherobot »
2011 Kymco Downtown 300i
motoman
« Reply #2 on: February 09, 2014, 03:54:13 PM »
Hi thesurgeonistherobot,
Yes, definitely in top - 5th gear. The Pulsar does have a tacho' and you can proceed to ride on into the red and reach around the manufacturers given speed of 60 - 65 MPH while in the red.  Here's how the manufacturer describes the engine power, 8.0 Kw @ 8500 Rpm.
The tacho' starts to redline at 8000 Rpm.
I have been told that to solve this I can fit a new front sprocket with one extra tooth. :-\
ophelia
« Reply #3 on: February 10, 2014, 12:07:39 AM »
You could change the front sprocket. It should be reasonable in cost. Are you the first owner of this bike? Has it been modified for greater acceleration before?
« Reply #4 on: February 10, 2014, 02:35:13 AM »
I had the same problem once... just change the sprockets and you'll get speed...
motoman
« Reply #5 on: February 10, 2014, 10:44:27 AM »
Hi thesurgeonistherobot and Vivo,
I'm the second owner. The bike had only just been run in (around 1200 miles) when I bought it in May 2013 and to date it hasn't been modified in any way. I've been quoted GBP£42.00, around US$69 including 20% UK VAT to buy and fit a new front sprocket with one extra tooth, which is okay I think. Will fitting a new sprocket effect the speedometer at all, do you know? ::)
« Reply #6 on: February 11, 2014, 09:45:19 AM »
The speedometer is attached to the front wheel, as long as you don't change the front wheel..it's ok.
I think Honda sprockets will fit... also, I think $69 is too much... Try searching for a set... front, rear plus a chain...
« Last Edit: February 11, 2014, 09:48:05 AM by Vivo »
ophelia
« Reply #7 on: February 11, 2014, 06:14:44 PM »
$69 with installation might be par for the course depending where you live. Shop rates can be pricey.
