Author Topic: kick start  (Read 2913 times)
hoffray
kick start
« on: August 28, 2009, 01:35:57 AM »
I cant get my Kymco people 150 to kick start. Is there a secret to it.
Thansk Ray
Shaka
Re: kick start
« Reply #1 on: August 28, 2009, 01:53:30 AM »
Not that I know of.  On my zx50; turn key to on, make sure kill switch in on run, and .  .  .  kick!  Usually fires first time!  Will it start using the starter?  When you kick it, does it crank the motor?
hoffray
Re: kick start
« Reply #2 on: August 28, 2009, 02:08:29 AM »
It starts right up using starter but not kick start
Shaka
Re: kick start
« Reply #3 on: August 28, 2009, 02:31:15 AM »
It should start right up with the kickstart then.  When you kick it, does it crank the motor?  My guess is that it may have something out of place or broken inside the cover preventing it from engaging.
PANCHOBARRONR
Re: kick start
« Reply #4 on: August 28, 2009, 11:24:57 PM »
Í am worst my people 50 ,2003 with 15000, te starter is dead ,and the kick start is broken ,i guess i will replace all the kick start parts first, that way i cna start my people even if my battery is dead
Shaka
Re: kick start
« Reply #5 on: August 29, 2009, 02:30:06 AM »
Have you taken the cover off to see what is going on inside?  You might not need any parts!  One of the gears may have just gotten stuck!
jmccoach
Re: kick start
« Reply #6 on: September 01, 2009, 02:39:54 PM »
I couldn't start mine until I put it up on the kick stand with the back wheel off the ground.
Shaka
Re: kick start
« Reply #7 on: September 01, 2009, 04:48:49 PM »
On my zx I can't use my kickstart unless it is on the center stand.  The arm hits the stand when it is folded up.
Re: kick start
« Reply #8 on: September 01, 2009, 04:50:34 PM »
..same with the Agility 50...gotta be on the center stand...
scoot1234
  • 31 yr. old hudsband and father of 4
Re: kick start
« Reply #9 on: September 19, 2009, 08:38:48 PM »
Thansk Ray
maybe it's the spark plug.  How new is plug?
I love this forum! It's the best i have found; Very informative, especially because of knowledable peeps.ex.: 'wordslinger', 'shaka', 'Axy' or 'Zombie' just to name four...
Honkerman
Re: kick start
« Reply #10 on: September 21, 2009, 01:04:16 AM »
Honestly, my People 150 will not kickstart either. I've had to jumpstart it on more than one occasion. I've checked inside the CVT, and everything seems to be meshing properly, but it just won't kick.
