There should be a a little piece of metal protruding from the metal casing or whatever its called around the fan, when you look straight at it its at about 8 o clock I believe. Line that little metal pointer thing up with the line marked T on your fan, then when you put your cam on look at the 3 hols in it there should be 2 small ones with line next to them and 1 larger one between the smaller holes. When you put the camshaft on make sure those two smaller ones line up with those little lines directly across from each other and parallel with the top of the cylinder head and the larger one directly at the top. There is something in the manual I found online at eserviceinfo.com under section 3. I hope you can understand my directions I know there are pretty sloppy but maybe someone else can elaborate.
Ken
