Author Topic: leaking oil  (Read 1152 times)
saltybobthepirate
leaking oil
« on: February 18, 2014, 01:35:35 PM »
Forgive me if this should be posted elsewhere.  My people s is an '09.  I know very little about engine repair or anything else mechanical.  I was told I needed a new stator so a friend (who is a mechanic) and I replaced it.  Then it still wouldn't start (battery was fine) and was told to get a new solenoid.  Replaced that and it still wouldn't run.  Turns out there was a faulty wire connecting the battery.
I just took it for a ride this morning (first time in about 5 months) and now there is oil all over the ground under my scoot.  It looks like its coming out from the stator cover.  I thought the stator had to do with charging the bike.  Should there be oil inside?
Thanks in advance!
big blue
Re: leaking oil
« Reply #1 on: February 19, 2014, 11:42:39 PM »
Hello salty, The oil filler/dipstick is just behind the stator. Is the cap missing or not screwed in tightly? If it is not oil will spew out  quite quickly.
Re: leaking oil
« Reply #2 on: February 20, 2014, 12:52:56 AM »
..gods, I hope the oil dipstick is missing or loose...
..if not, you might have disturbed the shaft seal behind the stator.......
                            :-X
« Last Edit: February 20, 2014, 12:55:00 AM by wordslinger »
abobotek
Re: leaking oil
« Reply #3 on: March 10, 2014, 06:41:32 PM »
My S 200 had what could be a similar oil leak.  The culprit was the cylinder gasket - the one between the cylinder and the crankcase.  It slid or was pinched out of position.  Not too bad of a repair, but it takes time.  I used a gasket shellac on the new gasket to help prevent a recurrence.
Red 2007 People S 200
Black 2008 Yamaha Majesty
