Did you miss your
activation email
Technical | How To
people 50 2t ,dead starter
Topic: people 50 2t ,dead starter (Read 1225 times)
PANCHOBARRONR
Newbie
August 28, 2009, 11:33:04 PM »
i have a 2003 people 50 with 15000 miles,the kick start is dead and the starter also is broken,i order the kick start parts, if a what to fix the starter do i nead the 1'''motor unit starter or 2''pinion assib or replace both this is the parts diagram
http://www.kymcopartsonline.com/catalog/search_diagram_detail.php?s_fk_manufacturers_id=21&s_fk_model_year_id=1&s_fk_scooter_model_id=6&s_parts_diagram_id=70
Shaka
Re: people 50 2t ,dead starter
August 29, 2009, 02:40:15 AM »
Remove the cover and check the pinion. It is probably fine. Check for worn or broken teeth. Once again, I would remove the cover and see what the real problem is before you order a bunch of parts (not cheap) that you don't need!
Back
