Author Topic: Wider Forks?  (Read 1092 times)
chucklestx
Wider Forks?
« on: February 21, 2014, 04:58:33 PM »
Has anyone considered/researched wider stem/forks to enable a wheel for beefier tire size? Where can I get the dimensions of a stem so that I can confirm it will fit but give me a wider gap between  forks?
« Last Edit: February 21, 2014, 05:08:19 PM by chucklestx »
Re: Wider Forks?
« Reply #1 on: February 22, 2014, 12:37:52 AM »
..what tire are you currently running on the front?
MotoRandy123
  • Lets Ride!
Re: Wider Forks?
« Reply #2 on: March 04, 2014, 09:36:50 PM »
Not many people moding scooters for a wider fork...
I'd look up the headset bearings on All Balls or some such site an then
see which other bikes they fit. You might get lucky. I know with bikes
the top and bottom bearings are usually different. I'm not sure how the
bearing company gets the info to make the bearings...
Re: Wider Forks?
« Reply #3 on: March 06, 2014, 12:07:21 AM »
..the oem ppl rear tire will fit the front...
...somebody here did that back in the day and loved the feel!!
