Did you miss your
activation email
Scooters - 50cc
Headlight Troubles
Topic: Headlight Troubles (Read 836 times)
Reignfire
Newbie
Headlight Troubles
February 23, 2014, 08:34:33 PM »
I have a 2013 Kymco Agility 50 and whenever I have to ride in the rain moisture gets inside the headlight housing and the bulb burns out. I've been having this problem for 6 months or so and have gone through about 6 bulbs. At first I thought the plastic housing wasn't air tight so I applied some auto epoxy around the seam but that didn't help. I also wrapped some black tape around the wires leading to the headlight because the rubber tube around the wires would hold water inside. That also didn't help. The scooter is still under the two year parts and labor warranty so would this apply? Everything else on the scooter is like new. Even if I can't get a replacement part through the warranty is there a site that'll let me purchase the headlight housing and wires? Thank you.
Re: Headlight Troubles
February 23, 2014, 09:30:51 PM »
My 07 scoot did the same thing when it was new.I put silcone around the whole light on the outside. there is some elc. grease you can put on the elec. parts so water dont bother it. I also have the relays all wraped in plastic.
Reignfire
Newbie
February 24, 2014, 08:01:51 AM »
If I wanted to get a new headlight where would be the best online store?
Reply #3 on:
February 25, 2014, 12:31:20 AM »
try kymcopartsonline.com
undead primate
Reply #4 on:
February 25, 2014, 02:26:25 AM »
..warranty!!
...take it to the dealer...they will order you a new headlamp assembly...
...or should....
peace
undead primate
Reply #5 on:
February 25, 2014, 02:28:06 AM »
..like blue, I had the same issues with my 08...
...I think we fixed our problem around the same time...lol..
..I didn't silicon outside, tho...
Last Edit: February 25, 2014, 03:16:34 AM by wordslinger
Back
