Author Topic: ..she let me down...  (Read 1357 times)
« on: September 01, 2009, 06:02:04 PM »
..Preparing for the trip to work today..crank my scoot for a warm-up..
..she stops running after about a minute and will not start back up..
..I can work the throttle and get some fuel into the carb...
..it'll run just a bit, till that fuel is gone.. :(
..this is the 4th time that this has happened..
..I will remove and dis-assemble my carb, (maybe I'll take those pics that guy wanted)...
..spray everything out, re-assemble, and everything is OK..
..why does this keep happening the first thing in the morning?? Never in the day, or night...
..hmmmm........  :-\
Shaka
Re: ..she let me down...
« Reply #1 on: September 01, 2009, 06:12:55 PM »
Pull of the vacuum line and suck on it to see if the petcock is good also.  Good luck!
« Reply #2 on: September 01, 2009, 06:15:21 PM »
...No...I ain't suckin on no lines...lol..
 ;D
Shaka
« Reply #3 on: September 01, 2009, 09:26:46 PM »
Don't be scared, nothing should come out it!  ;)  If you have a clear fuel filter you should see the fuel flowing through.  I do this all the time on mine to fill the carb bowl back up after I change my jet.  That way it fires right up instead of having to wait for the motor to pull the fuel down to it!
« Reply #4 on: September 02, 2009, 10:38:09 AM »
...aahh, yeah,...that's a good idea!!!
« Reply #5 on: September 02, 2009, 01:15:18 PM »
..I went ahead and drilled my main jet port open, while I had my carb apart..
..not knowing what the difference between an 80 and an 85 jet should be..
..wow!!!...
..Lots more punch on take-off and I maintain speed on semi-flat roads MUCH better...
