Author Topic: home made choke  (Read 585 times)
home made choke
« on: March 13, 2014, 01:13:44 AM »
this works great. Just cut the wires off. and drill a hole threw the top so you can stick a small screw driver in it to push down on the insides of it when you turn the scoot over it realy work great on theam cold days.
« Last Edit: March 13, 2014, 01:15:42 AM by blue »
tortoise
Re: home made choke
« Reply #1 on: March 13, 2014, 02:47:53 AM »
Please clarify.  Extending the needle down would block fuel flow through the enrichment passageway . . video.
Re: home made choke
« Reply #2 on: March 13, 2014, 08:55:53 PM »
Yes I know what you are doing is blocking off too much gas geting up to the enrichment. which forces more gas to go straight threw the carb.for better start.  I have been doing this for about 2 years now And the scoot starts right up. and on a normal day of 30 * or better I dont need the choke. if ya have a extra choke give it a try and see for your self good luck im sure you will like.
