Author Topic: starter/brake lever  (Read 687 times)
grommet
starter/brake lever
« on: March 13, 2014, 03:32:49 PM »
Hi, I have a people 125 and the starter only works when I apply the front brake, not the rear as it always has. It's not a major problem it's just that it's a bit tricky turning the throttle whilst pulling the brake. I would be grateful to know how to fix it. Cheers :)
Jim Moore
Re: starter/brake lever
« Reply #1 on: March 14, 2014, 11:39:39 AM »
There is a switch inside the housing. Sometimes they go bad. The switch on my Agility 125 is under a bunch of plastic, so I can't tell you how to get it out.
Here's something else to check. See if your rear brake lever activates the brake light. I bet not, because it works off the same switch.
grommet
« Reply #2 on: March 14, 2014, 04:53:35 PM »
Thanks Jim, brake light not working as you say, will check it out
« Reply #3 on: March 14, 2014, 11:48:10 PM »
See topic post which fixed the same problem!
http://www.kymcoforum.com/index.php?topic=11117.0
