Author Topic: dif.Kind of carb  (Read 571 times)
dif.Kind of carb
« on: March 24, 2014, 08:49:00 PM »
I came across a 20 mm carb I thought I would try on the scoot. the scoot ran fine tell I hit 30 then it slowed down and would not go any faster. So I took it apart to clean and the bowl was the same as a gy6 carb. But the float and the diaphragm was dif. :o  Never seen anything like it befor.The diaphram had black sliders on it and the needle had a top on it so you cant adjust it at all. and for a 20 mm carb the outer hole was a ture 20mm but the insides were like 15 mm what the hell. any one have any ideas...............
245luigi
  • Boston, MA
Re: dif.Kind of carb
« Reply #1 on: March 24, 2014, 08:54:55 PM »
Photos may help us!
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
« Reply #2 on: March 25, 2014, 12:00:22 AM »
ok that i can do.
joebro
« Reply #3 on: March 25, 2014, 04:19:25 AM »
 :o Hmmm well thats a new one for me!
You only live once but if you live right once is all you need.
