Author Topic: Gas is evaporating or leaking  (Read 1282 times)
Howard
« on: March 31, 2014, 01:20:55 PM »
I parked my KYMCO Agility 50 in an unheated garage (with plenty of openings for the wind to enter) over the winter with a full tank of gas including stabilizer. When I returned 4 months later, the gas tank was empty. I filled it with gas and everything ran fine. Did the gas evaporate over the winter or do I have a leak?  Where should I look?
Thank you.
MaryK
Re: Gas is evaporating or leaking
« Reply #1 on: March 31, 2014, 02:43:11 PM »
You should check the oil in the engine.  It can happen that the gas leaks through the carbs into the engine.
That is not good.
scoot safely,
New Rider in 2010
2009 GrandVista 250
MoToFaLcon
  • I Fly....
« Reply #2 on: April 01, 2014, 04:01:22 PM »
What!!!?  Thats weird?  Maybe someone syphoned it?  Did you check the oil like maryk said?
WTF, i have a Ninja 650!!
Howard
« Reply #3 on: April 01, 2014, 07:03:53 PM »
I will not have access to the bike for another week. At that time I will check the oil. Thanks for the advice.
Howard
« Reply #4 on: April 02, 2014, 11:49:17 PM »
check and see if the pedcock has a slow leak........Or a leak in one of the gas lines.
phatboy
« Reply #5 on: April 03, 2014, 07:51:15 AM »
some one could of went joy riding on your scoot
does any one else know where you keep the keys?
Agility 50 w/72cc BBK, A9 cam, stock airbox and exhaust (both drilled out), remove air tube restriction, stock head, stock carb, 105 main jet, CDI cut, smooth variator boss, stock variator w/5g rollers
« Reply #6 on: April 03, 2014, 08:39:05 AM »
That's really weird...  :o
Howard
« Reply #7 on: April 03, 2014, 12:38:12 PM »
The scooter has been in a locked garage all winter. No one had access to it and no one took it for a ride.
Howard
