Author Topic: AnyOne else - Vacuum in fuel Tank?  (Read 1063 times)
« on: April 03, 2014, 02:19:45 AM »
OK, back again with this question.
Is any one else finding a vacuum in the fuel tank when they open the cap?Symptoms are : sucking noise and cap stuck on filler neck a bit - when opening.
This happens nearly every time I open the cap after being parked - but only sometimes after being ridden.
One comment from a veteran scooter rider/mechanic is that this is due to fuel having over-flowed into vent tube - and now small PVC valve is clogged. Differing air temps causing fuel to expand and contract....and fuel cap cannot vent  air in....only out. My mechanic says venting out is normal. One remedy is to cut the vent tube from the filler neck and let it hang - so the tank can vent - in and out.
My concern is or course a scoot that cuts off or boggs in traffic from fuel starvation. This has never happened, yet.
Any ideas?
Thanks, Stig
Re: AnyOne else - Vacuum in fuel Tank?
« Reply #1 on: April 03, 2014, 02:54:26 AM »
True this can happen all I did was take a gas line of and let a little air in the tank and the cap came right off.
TroutBum
  • 2012 Like 200i (sold)
« Reply #2 on: April 03, 2014, 04:13:19 AM »
Since you're still under warranty, take it to your dealer and let them fix this issue.
08087
  • 09' Peoples 200, NJ
« Reply #3 on: April 03, 2014, 06:24:51 PM »
I can't say it happens to me.
« Reply #4 on: April 03, 2014, 11:25:09 PM »
Trying to sort out if it is an issue - or is it what happens when you ride a scooter.
Taking it to the dealer is a .....project in itself this time of year. They are knee deep in big bikes for spring riders.
If my scoot acted funny in the slightest way - I would be down there at sun-up. It runs fine - just wondered if another LIKE owner could pull his gas cap after it sits after a ride and see if the tank inhales?
LidoCA
  • I LIKE chinese plastic.
« Reply #5 on: April 09, 2014, 02:44:09 AM »
 I finally had this happen. It was on Sunday morning and I opened the gas cap. Air rushed in, then gas came out. In hindsight, I am not sure if it was pressurized or in a vacuum. It did remind me of an answer from your previous post, about over filling the tank. I filled the tank higher than normal. Normally the gas pump shuts off at about three quarter tank.  I filled it over the cross bar in the tank. I don't know if that is supposed to be true cut off point. Since then, as the tank level has dropped, it has not happened.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
donandrews
« Reply #6 on: April 09, 2014, 03:30:43 AM »
Page 12 of the Like manual says not to over fill. "There should be no fuel in the filler neck." Don't think this will answer your question, Stig, but it may help LidoCA. We don't have self serve in Oregon so I just tell them to fill it to the bar and try to go the the same station all the time.
Peace and Ride Safe
2012 Like 200i
Lusting for People 300GTI, but recently purchased Vespa 250GTSie instead.
Brownsville OR
Home of Willamette Country Music Festival and
movie "Stand By Me"
Normal is Relative
