Author Topic: pot holes  (Read 731 times)
pot holes
« on: April 04, 2014, 10:11:34 PM »
Be safe this year guys the pot holes are about the size of your scoot.the hard winter made for a lot of big pot holes
08087
  • 09' Peoples 200, NJ
Re: pot holes
« Reply #1 on: April 04, 2014, 11:28:22 PM »
Amen to that! Leave extra room between you and that truck, bus or car in front of you so you have ample time to react when that gaping hole appears from under them.
bluesin
  • 2012 DT 300i
Re: pot holes
« Reply #2 on: April 05, 2014, 12:19:05 AM »
Lobstermen are setting their traps in them out here ! Think I saw a Beluga Whale poke his head out of one .  :o
joebro
Re: pot holes
« Reply #3 on: April 05, 2014, 10:27:45 AM »
Yesterday riding a back road I encountered what I like to call the double pothole. Two equally big potholes about a inch from each other basically forcing you on to the wrong side of the road to go around them. I should have took a pic.
You only live once but if you live right once is all you need.
houndguy
  • Fear the mangy mutt!
  • Your idiotism amuses me.
    • Scooter Revolution!
Re: pot holes
« Reply #4 on: April 05, 2014, 11:30:04 AM »
Even in Florida the potholes are miserable.  Of course, we are also using so much freaking sand in the mix that it's like glass.  So to combat that they use broken shells.
No.  I am not joking.
Just another scooter blog - http://www.2smallerwheels.blogspot.com
08087
Re: pot holes
« Reply #5 on: April 05, 2014, 06:25:10 PM »
I've got to love the Hudson Co. NJ answer to pot holes. While sitting at a light today along a truck route I see 2 "workers" fill a couple of smaller pot holes (maybe 2' in diameter), pat the tops of them with the shovel and leave.
My guess is those holes will be open again in about 3 minutes. or the first 18 wheeler the rolls a couple of axels across them.
