Author Topic: What type of battery should I get for 2013 Agility 50?  (Read 752 times)
stoneboy
« on: April 05, 2014, 03:14:20 AM »
Hello,
My scooter's battery is getting weaker and weaker. I would like to buy a replacement before it died, but I have a bad luck with YUASA YTX5L-BS as I had two of them already. And my scooter is 2013. Could you guys recommend a better battery to buy? There are so many of them when I search on Amazon.com or ebay. Do I just need to look for one that is YTX5L-BS type? Is there anything else that I should consider?
The owner's manual says that the battery spec is 12v-6Ah.
Thanks so much for your help.
Re: What type of battery should I get for 2013 Agility 50?
« Reply #1 on: April 05, 2014, 03:34:18 AM »
Get the biggest that would fit,, your scoot will love it!   I switched from a 7 to a 9amp... it's just slightly taller... great cranking power!
stoneboy
« Reply #2 on: April 05, 2014, 12:18:42 PM »
Great! May I ask what model no your battery is. Thanks!
« Reply #3 on: April 06, 2014, 11:42:00 PM »
Wow a 9 lb I went up to the 7 from a 5 maybe next winter ill try a 9 IM looking for more cranking amps for in the winter time...................
