Author Topic: Dr Pulleys installed  (Read 669 times)
« on: April 09, 2014, 08:15:30 PM »
See the tech section at the top of our forum for pix of a Dr Pulley slider installation.
New things learned: take that left side rear 10mm bolt out of the license plate thing to make the replacement of the lower side panel a WHOLE lot easier! It also clips into that side panel.
And, the 3M Gasket Adhesive worked a charm for getting that new gasket to stay in place.
Later today I will take the scoot for a ride to see changes found by going up from 13 gm to 14gm slider weights.
