Author Topic: how fast should my agility 50 be going after mods  (Read 2025 times)
amccraw0
« on: September 08, 2009, 08:06:54 PM »
sofar i have deristricted my cdi performance variater 6gram roller weights derestricted variator and it will do 42 on flat ground
Re: how fast should my agility 50 be going after mods
« Reply #1 on: September 08, 2009, 08:21:18 PM »
..when I bought my '08 A50 new, the dealer said it would run 42 derestricted...
..now, I installed a Malossi multivar variator with 5.5 gr rollers, along with the longer main clutch spring that came with it..
..drilled my main jet to an 85, from the stock 80..
..keep my valves adjusted to .04mm ..
..keep my tire pressures at spec..
..run highest octane fuel I can get...
..I generally run between 42 and 47 on "flat ground", GPS verified, cause you cant go by your speedo...  ;D
..I have, under ideal down-hill conditions, pegged my speedometer..
« Last Edit: September 08, 2009, 08:24:05 PM by wordslinger »
amccraw0
« Reply #2 on: September 08, 2009, 08:42:29 PM »
yeah downhill i went passed the speedo too so that normal speeds that my scoot is doing
« Reply #3 on: September 08, 2009, 09:04:06 PM »
..probably...cant get but so much outta 49cc, 4-stroke engine..no matter how you gear it...
axy
« Reply #4 on: September 08, 2009, 10:18:09 PM »
73 mph indicated on my 125... develops interesting sounds @ that speed though... ;D
Kymco Agility 125 2008
« Reply #5 on: September 09, 2009, 10:24:27 AM »
..my A50 actually smooths out more @ 48-53...smooth and sweet...
