Author Topic: How to adjust low beams?  (Read 2214 times)
kneeslider
« on: April 10, 2014, 04:32:51 AM »
Hello,
How do i adjust the low beams on the DT?
FYI, my low beams are the lower projector lights.
Thank you.
2019 Yamaha X-Max 250
de-dee
Re: How to adjust low beams?
« Reply #1 on: April 10, 2014, 03:11:00 PM »
   there is a panel over the front tire , one screw on each side take that off and you can reach the leveling screws ,.  I used a stubby #2 philips screw driver,.  thats the red one,. if you can get someone to sit on the scooter you can see how far the light go,s and have a piece of card board to cover one light so you can see what you are doing with the other light,.
kneeslider
« Reply #2 on: April 11, 2014, 02:13:26 AM »
Thanks,
Are they adjustable sideways?
de-dee
« Reply #3 on: April 11, 2014, 04:06:57 AM »
  I took the front end off when I changed the bulbs, that was befor I found out the little panel over the wheel gave access to the light adjustment screws, I did not see any side adjustment ,.only distance,.  I tryed all the high output bulbs then I went to HID bulbs  and they lite the front and sides very nicely,.
de-dee
« Reply #4 on: April 11, 2014, 04:19:18 AM »
 using a # 2 philips screw driver just turn the adjustment screw left or right until the light is at the level you want,look under and up at the back of the lightyou will see where to put the screw driver, a cross slot ,
kneeslider
« Reply #5 on: April 24, 2014, 07:43:41 AM »
Adjusted my headlights last night.  Didn't have to remove any panels.  Just reach underneath and the adjustment screws were easily reached. Just needed a short phillips head.
sklnzl
« Reply #6 on: June 10, 2014, 02:20:10 PM »
Hi there ,is the adjustment of the high beams do-able without removing front faring as it is done for the low beams ? ???
« Reply #7 on: June 11, 2014, 01:40:52 AM »
yes it is,  just a little longer reach,  I am old and dont bend very well,  thats why I take the little panel off over the front wheel,
karimfadl
« Reply #8 on: August 26, 2014, 09:48:50 AM »
would anyone kindly post pics for the location of adjustment screws of the "high beam"?
thanks in advance.
« Reply #9 on: August 31, 2014, 06:55:39 PM »
if ou know where the screw is for the high beam it is the same place on the low beam module
