Author Topic: How to check condition of the belt?  (Read 1231 times)
kneeslider
« on: April 11, 2014, 03:00:58 AM »
Hello,
After opening up the belt covers, how do one inspect the belt of it's condition?
Do I need to remove it and flex it backwards to check for micro cracks?
2019 Yamaha X-Max 250
245luigi
  • Boston, MA
Re: How to check condition of the belt?
« Reply #1 on: April 11, 2014, 03:50:37 AM »
Visual inspection and there is a service limit for the maximum width of the belt. For example on the Like 50 a new belt is 18mm wide and the service limit is 16.5mm wide
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
de-dee
« Reply #2 on: April 11, 2014, 03:55:23 AM »
   yes I did flex the belt and measured the width of the belt it was still at 24 mm, I had 30,000 km.s  on the belt befor I changed it, it looked good until I flexed it,    safe riding  Don   300i downtown
« Reply #3 on: April 11, 2014, 08:22:58 AM »
There are two things to consider... wear and tear that you can see and those you can't see
I only do a periodic check for abnormal wear and tear and cleaning... then I change every 15,000 kilometers regardless of the condition... you can never know when it'll just snap...
kneeslider
« Reply #4 on: April 12, 2014, 08:00:39 AM »
I was told if you ride aggressively and/or run top speed consistently, the belt will wear faster. On my daily 40km round trip, about 30km is top speed WOT and about 80% of acceleration is WOT. Would a 10000km belt change or 15000km belt change be more reasonable.
FYI, I am on a DownTown 200.
And, is the belt for the DownTown 300 and 200 identical?
de-dee
« Reply #5 on: April 13, 2014, 10:40:37 AM »
  our manual does not tell what the sizes are, my 300i belt measures 1004 mm. / 24 mm. and once I found a measure from mitsuboshi and it was 1004/25.2 mm.with 30 degree pitch  my first belt that came in the scooter was 1010 mm. / 24 mm. the next two belt I bought was 1004 /24  mm.  to measure your belt get the wifes tailor tape (cloth tape)  and measue around the belt,  cross checki the tape with a steel tape, because cloth tapes strech
kneeslider
« Reply #6 on: April 14, 2014, 12:20:07 AM »
I guess the best way then is to open up the cover and have a look at what is printed on the belt.
I think I'll just pop into the dealers and take a pic of a new belt. Yes, I'm lazy. =)
« Last Edit: April 14, 2014, 12:21:52 AM by kneeslider »
