Author Topic: Fastest ZX -50) In the USA... Zombies Scoot.  (Read 8965 times)
Re: Fastest ZX -50) In the USA... Zombies Scoot.
« Reply #15 on: April 17, 2014, 03:00:51 AM »
OK... Here we go.
Parts installed:
Jasil /top racing variator
Polini 4.5gr rollers
Nakaru variator shim ki
Dual crank shaft seals
Ruima stuffer/stroker crank shaft 44mm??? I forget
Bando OEM belt
Stage6 RT II Clutch
Stage6 Race bell
Polini Torsion control pulley
Malossi secondary gears   (OEM 10.1:1)  Malossi 8.1:1  (Steves 5.6:1)
Moped Hospital Primary gears (custom cut for Steve)
All new shims/bearings in the gear case
INSANELY flow ported cases, and intake tract
Polini Corsa 72CC kit (actual is something like 77cc w/ stroker)
2.5mm raise on exhaust timing, and boost port
Widened intake ports (I forget how much...75%???)
Whatever that popular intage/reed cage is???
.022 Reeds
Oko 28mm (power boost model)
Jets from 0 - 1,000,000,000
Needeles from a - zzzzzzzzzzz
HPI Programable Ign. w/ 2 cdi's 3 rotors/3 custom wound coils
HPI 40,000 volt coil
Hi flow fan/directional scoop air intake
Malossi brake shoes (rear)
Malossi Pads  (front)
Pirelli Diablo tires
Bolt in valve stems
Kymco Agility front forks
15mm fork spring shims
drilled dampener relief valves (forks)
Agility dual piston front caliper
Yamaha 15 tooth speedo sender gear (12" tire)
Yamaha 90 mph speedo
$100.00 EGT gauge Street bike 2t forget the brand but is USA made
12k Tach
HAnd made Inst. cluster
ALL the plastics have been modified, and made modular. 3 minutes to remove it all
fiberglass belly pan for air flow to engine
Custom made seat cover to match paint
Bar end mirrors
Hatchet mirrors
Anodized Grips
Modified bars for naked running
Ign kill lanyard
My Favorite... Hand made for the engine...Scorpion Pipe w/ Team Scooter Alley tag
Parts to go with the bike:
Second unmodified complete engine
2 or three jugs (forget what they are) 2-3 heads 2-3 pistons/ring sets
Expansion pipe (jiangwayne) Has a few small cracks to be welded
Technigas rsII
A few silencers
A pile of used but good tires
New Stage6 clutch shoes
assorted cvt/clutch spring kits/
assorted roller kits
Loads of engine seals, and gasket sets
more LED bulbs than you could ever use
several stators, and flywheels
19mm Delorto carb, and jets
complete OEM headset w/ gauges
I forget what else is out there but it will all go w/ the bike
I never finished wiring in the lights or egt gauge so it is all new. The port for the EGT thermocouple is stainless, and welded into the pipe already.
 If you wear a size 44 (large) I will include the race jacket too. That was pricey, and I wore it once.
I forgot... Frame stretched 3", and lowered 1.25" Hand made shock extension, and S-9 shock installed
Blacked out running lights
Ford f350 dark tint running lights converted into head lights for the bike
My friggin head is spinning~~~~~~~   Maybe 4-6 grand in stuff???  Maybe 1,000 hours of labor??? I forget.
400.00 in paint / stickers alone
Kill me... Please!
I'm gonna see if this will work for my signature :o
« Last Edit: April 17, 2014, 03:04:28 AM by zombie »
LoveMyKymco
« Reply #16 on: April 17, 2014, 04:19:20 AM »
You guys have till next Wednesday to pay this man in full or its mine.  ??? Thats only 6 days to decide if a one off scooter with some extremely cool and expensive parts is worth a mere 1500.  :D
« Reply #17 on: April 17, 2014, 04:24:13 AM »
Love ya Bro!   Thanks!
« Reply #18 on: April 18, 2014, 01:26:21 AM »
Just put it up on Uship to get some idea of cost, and PM'd Lovemy the details.
I stated in the PM that if he wants it... great. If not then no skin lost, and all is golden.
Just for general info Uship lists a "name youe price cost of 390ish to Mo. USA, and a published rate of 600ish.
The bike is coming from Carrabelle Fl so if anyone wants to get shipping quotes...
As I said I will split the cost 50/50 w/ the buyer. I may even be able to drive 8 hours one way to deliver or meet in the middle kind of thing. If it's a deliver then 50/50 fuel. Meet in the middle... to each their own
Ps. I listed it as 180lbs crated with the extras,
« Reply #19 on: April 19, 2014, 08:43:33 PM »
Got the first bid on Uship. 379.56  to St. Louis. Enclosed trailer! Even if there are no other bids it sounds fair to me.
« Reply #20 on: April 21, 2014, 03:00:18 AM »
Too many to read..Lol!   8)
« Reply #21 on: April 21, 2014, 03:25:27 AM »
I didn't list the:
Malossi Red contra
Stage6 stiffest fly springs (forget color)
Work on the CVT cover
Work on the fender (rear)
Kickstart lever cover
2 piece Stage6 throttle cable
Oil injector block off
Drilled out Fuel petcock
Created vacuum port in carb (less pulsing than manifold for better fuel delivery)
Power boost block off, and extra jets for that
Modified throttle return spring (softer)
New rear brake cable
Modified brake return spring (stiffer)
6-8 heat ranges (spark plugs)
Assorted cylinder shims (change compression ratios)
Full synthetic gear oil (Napa 90wt)
ALWAYS run on Golden Spectro Platinum 32+ (2T oil ,16 bucks a pint)
New front wheel bearings
Reinforced vinyl Carb coupler
Did I mention it is modified??
It's modified!
Oh! AND I'm throwing in a vacuum tester from Josh at Scooter Invasion. That was 215.00 by it self.
Going to puke now... Z
« Last Edit: April 21, 2014, 03:29:58 AM by zombie »
« Reply #22 on: April 21, 2014, 05:13:46 AM »
Lol! I thought you were listing your store's inventory...!
« Reply #23 on: April 21, 2014, 01:45:09 PM »
Me Too! LOL
4 more Uship bids  $29937 is the cheapest, and can pick up on the 24th deliver on 27th
« Reply #24 on: April 22, 2014, 10:09:50 PM »
SOLD!!!
Beowulf479 has answered your question about their bid on your shipment, 2005 Kymco ZX 50.
Your Question:
"Hello, Thank you for your bid. The person buying this bike has posted his payment. I can have the bike ready for pick up Friday the 25th. Thursday the 24th is also an option if it makes a difference. I hope this is good for you. How do I proceed from here? Are you paid in full at pick up? Delivery? Any help from this point forward is appreciated. Thanks again... Ken"
Answer:
"Friday or Saturday is good for me, maybe even Monday. When you accept my bid, you'll pay uShip in full and they will hold the money until I make the delivery. Then you can give me an 8 digit code that will release the payment into my account. This way if there's ever a problem uShip can regulate it."
Accept Bid >
Ask Another Question >
Bid amount: $299.37
Bid Expiration: 4/23/2014
Shipment: 2005 Kymco ZX 50
To: Saint Louis, Missouri 63103
This is the email from the Uship bidder I chose. Let me tell you all something. This Uship is the Ebay of shipping. One of the easiest things I have done in years.
I was worried about calling 100 different shippers, and dealing w/ "We gotta come see it, and It needs a Plutonium jacket DOT FBI CIA F'in FED shipping label"
If you wanna ship an odd item or I guess anything... This is what I will be doing from now on.
I'll let the buyer chime in if he wishes but just so ya know... I traded for 3 stuffed ostriches (African variety), two SeaLand Vacuflush Marine toilets, and a real live Orangutan. I guess the fella came from Africa by boat, and had the animals w/ him. Probably heisted the toilets but who cares.
Here's my monkey... I'm told he looks a little    Off    But he is supposed to be real sweet. xoxoxoxox~
I'm gonna call him Lil' Vivo
« Last Edit: April 22, 2014, 10:12:36 PM by zombie »
« Reply #25 on: April 24, 2014, 04:51:31 AM »
LOL... FOR SALE STILL!
Peters
  • In Glock I Trust
« Reply #26 on: May 05, 2014, 05:23:56 AM »
Damn zomb, finally find the thread on what you've been up to all this time. You're an engineer for sure, even if you don't have a degree in it. Smarter than me, and 99% of the people I know.
This is the third time I've said it... I want some of that shine bro  ;D . I understand getting into another hobby. I'm tied up with so many projects right now. Also, I'm transfering to a 4 year school, so I'll be moving in August. Raleigh or Charlotte. Really looking forward to it. Just bought a little 87 Ford ranger for $600. It's in really good shape. I got a steal. Still working on my 2 stroke quads. Unfortunately they may take over my interest in scooters. Doesn't mean I won't keep my 2 kymcos and I certainly intend to stick around as long as you zombie, slinger, and vivo are around.
Say zombie, if you don't mind sharing with the Kymco world, where are you moving to?
Wish you best in selling the Z man zman  ;) :D Keeping this post fresh for ya ;)
*2001 ZX-50 beater
« Reply #27 on: May 05, 2014, 05:30:50 AM »
I'm not moving anymore. Carrabelle is my home now.
You are right up the road from me so when you get settled in I will be here, and my home is open to you, and yours.
Maybe the moon will be shining, and maybe I'm just ACTING like the guys on tv. Guess you will have to find out!
That's my story. and I'm stickin' to it. "FTP"
Peters
  • In Glock I Trust
« Reply #28 on: May 05, 2014, 05:39:39 AM »
I'm with ya man. I'd love to visit you, and I'm not just saying that. Unfortunately, as you know I'm not legal to operate a 4 wheeled motor vehicle right now. Soon though man, very soon. Kept my head down low for 4 years now. A Florida road trip next summer may be in the cards for me. If so I will definitely stop in for a visit. Not making any promises though. I have a good friend that lives in the keys too. Would love to go see him too.
*2001 ZX-50 beater
« Reply #29 on: May 05, 2014, 05:43:11 AM »
Always here Peetes. 904 209 7ZERO91
Did I say this before? FTP!
« Last Edit: May 05, 2014, 05:53:02 AM by zombie »
