Author Topic: Ermax windshield / headlight install change  (Read 1049 times)
Trucker jay
« on: April 15, 2014, 02:28:25 AM »
I just installed a Ermax windshield from moto machines $116 or $106 with shipping.  Removing the front panel was easy.  The headset cover was hard to figure out.  I put changing the headlight in the topic because its the same procedure.
1.  Mirrors don't bother with the small nut under plastic cap.  The nut you need is 17mm under the rubber boot.
2.  The back half will come off after removing 2 bolts on steering neck, 2 Philip screws by the switches then some taps to undo. That will expose the back side of the headlight.
3.  I think one of the mirrors is a left hand thread so don't mix them up.
4.  The tabs two on top the others along radiator cover push the center in then pull tab out.
I spent two hours trying to remove the mirrors and trying to pop off the face off the headset all the wrong way.  Easy job once you figure it out maybe 2 hrs total with hooking up euro turn signals and all.
