Author Topic: [SOLVED: For Now]Saddle bags for a Super8?  (Read 3647 times)
DMblues01
  • 2012 Kymco Super 8 150
« on: April 18, 2014, 03:00:32 PM »
Anyone know of any decent soft saddle bags that will fit on a Super8 150?
I'm just looking for a relatively inexpensive solution to have some more storage from time to time, that is easy to remove when I don't need them.  I've seen a couple of nice ones on other scoots, but they look too big for the Super8.
I'll probably end up getting a top trunk at some point, but trying to avoid that as long as possible since it puts the load so high on the scoot.
Any suggestions are welcome.  Thanks!  :)
« Last Edit: June 11, 2014, 06:31:20 PM by DMblues01 »
Roxana, IL
Yoda is my spiritual leader.
tjupille
Re: Saddle bags for a Super8?
« Reply #1 on: April 20, 2014, 01:44:45 AM »
Look on FleaBay for ATV tank bags. They will drape over the rear of the seat, but then it's a PITA to raise the seat to get at the pet carrier or gas. I ended up cutting them in half and then screwing them down to the rear fenders just below the seat. I keep all the "semi permanent" stuff in there (windbreaker, cable lock, bungee net, etc.) which leaves the pet carrier available for cargo.
DMblues01
« Reply #2 on: April 20, 2014, 04:35:18 AM »
Well, I don't want to do any add-ons that can't be un-done without leaving marks. I plan on trading it in for something a bit bigger when my wallet allows.
I've seen a few that the straps go under the seat to hold in place. I like that setup. I may look at my local bike shop to see if any motorcycle bags have long enough straps to work that way. I might get lucky.
Moot point at the moment, since the damn thing won't start anyway!  >:(
But that's a whole different story!
Roxana, IL
houndguy
  • Fear the mangy mutt!
  • Your idiotism amuses me.
    • Scooter Revolution!
« Reply #3 on: April 20, 2014, 02:02:47 PM »
Try http://www.formosasaddlebags.com/
I know they make bags for smaller scoots.  :)
Just another scooter blog - http://www.2smallerwheels.blogspot.com
DMblues01
« Reply #4 on: April 20, 2014, 02:11:42 PM »
Thanks for the link! I'll have to give a more detailed look at them on my day off.
Roxana, IL
DMblues01
« Reply #5 on: June 08, 2014, 02:51:02 PM »
Well, I may have found some bags for my Super 8.
I found a set of Nelson-Riggs saddlebags designed for sport bike applications. They're fairly small sized, so they shouldn't be to big for the scoot.
I ordered them from denniskirk.com for $70. Should be in by Wednesday.
I let y'all know how they work out.
Live to Ride!
And Ride to save gas!!  ;D
Roxana, IL
blackhawkfan
« Reply #6 on: June 08, 2014, 11:21:03 PM »
On the NY scooter club forum, someone has posted about using soft sided coolers as saddlebage.  I've bought a couple, connected them in the middle of the straps, and can put them on when needed by putting the straps under the seat.  One of these days I'm going to attach a couple of reflectors I have on hand to the coolers for some extra visibility.  The coolers I bought are the ones that hold a sixpack.
Proud owner of a red 2013 Kymco Super 8 150k
Scooter is stock
wkreps
« Reply #7 on: June 09, 2014, 01:21:34 PM »
blackhawk,
That's a slick idea for someone who just needs a little extra space once in a while. I'll be looking into that.
Wayne
DMblues01
Re:[SOLVED: For Now] Saddle bags for a Super8?
« Reply #8 on: June 11, 2014, 06:13:21 PM »
Well, I got my Nelson-Rigg saddle bags today. They don't fit perfect, but nothing does on a Super 8!
The only issue I found is the left bag covers the key hole for the seat latch. I fiddled with the mounting straps for a bit, and set it up so I can release the quick release that goes under the tail and undo the velcro support strap on top, and then the bag swings out to access the seat latch key hole. Then when I close the seat, the support and hold down strap hook back up in about 5 to 10 seconds. Piece of cake!!  8)
Roxana, IL
DMblues01
« Reply #9 on: June 11, 2014, 06:15:12 PM »
A couple more angles!  :)
« Last Edit: June 11, 2014, 06:31:59 PM by DMblues01 »
Roxana, IL
