Author Topic: Front Axle Diameter & Wheel Balancers  (Read 944 times)
MaryK
« on: April 20, 2014, 12:33:33 AM »
The front axle is 12mm in diameter on the Grand Vista 250.
 When I took the scooter in for new tires, the mechanic could not balance the front wheel
because his wheel balancer had a shaft diameter larger than 1/2".
So I finally found a tire shop that had a balancer with a 12mm shaft and got the job done.
Might want to check with your garage before getting new tires to see if they can balance them.
Avon tires.
scoot safely,
New Rider in 2010
2009 GrandVista 250
Hueffenhardt
Re: Front Axle Diameter & Wheel Balancers
« Reply #1 on: April 20, 2014, 02:04:36 AM »
Yeah, I recently got new tires and I had a shop that specializes in scooters balance and install them.
2008 Kymco Grand Vista 250cc, white
I am new to the motorized two wheel lifestyle (Mar 2014).
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #2 on: April 30, 2014, 12:54:43 AM »
The use a really small size.  Harbor freight sells a tire changer but then you have to buy the adapter for it to work on a scooter.
PaulC
