Author Topic: Help! My scooter won't start.....  (Read 724 times)
brianb
« on: April 22, 2014, 02:01:58 AM »
I have a 2012 super 8 50 2t and at the moment it's my primary mode of transportation.  It stalled a couple times while driving it full throttle and now I cannot start it.  It "cranks over"....but won't start.  The gas is good, fill the tank every week with ethanol free gasoline.  I changed the spark plug and cleaned the air filter.  My next step is to check fuses than check to see if I have spark.  Any suggestions/advise?  Thanks!
Re: Help! My scooter won't start.....
« Reply #1 on: April 22, 2014, 03:31:56 AM »
The fuse is therre for the starter motor. If there is an Ign. fuse I am unaware of one.
Test for spark. fuel in the cylinder. and compression. It is one of them.
Several auto shops rent compression testers or you can buy a decent one for around 30.00 at Ace Hardware
Screw the tester in, and have the throttle wide open to check. It should be at least 120 psi on the gauge.
brianb
« Reply #2 on: April 22, 2014, 11:54:37 AM »
Ok.....I'll do that.  Thanks!
