Did you miss your
activation email
Motorcycles
Venox 250
new member and new owner of a venox 250
Pages:
3
4
Topic: new member and new owner of a venox 250 (Read 8148 times)
oldspower24
Newbie
Re: new member and new owner of a venox 250
Reply #45 on:
May 11, 2014, 08:23:08 PM »
Yea I changed the oil and filter. That was the first thing I did. I'm going to get a new shifter linkage and the return spring. So the return spring could stop the bike from shifting? I've never had to mess with a return spring b4
You never know do ya!
Close enough to get the idea!
Reply #46 on:
May 11, 2014, 08:33:04 PM »
Does the shift lever try to stay in whatever position you click it into? Or does it naturally return to the center position.
oldspower24
Newbie
Reply #47 on:
May 11, 2014, 08:43:54 PM »
It returns to the center position
Reply #48 on:
May 11, 2014, 08:50:27 PM »
Well then it's not the index spring. Go to
http://www.stadiumyamaha.com
and look up your bike. You can follow the bread crumbs to see if you can locate a broken part. It may also just be part of the linkage is bent to the point it is out of adjustment or spec.
Go thru the service manual for the adjustment procedure to see if it is something there.
oldspower24
Newbie
Reply #49 on:
May 11, 2014, 09:42:18 PM »
Thanx I'll look into that. Gotta get the service manual
Reply #50 on:
May 11, 2014, 09:45:43 PM »
http://www.kymcoforum.com/index.php?topic=495.15
It's here. I posted it a day or two ago.
Back
