Author Topic: kymco 50 like  (Read 1403 times)
gardeb
kymco 50 like
« on: April 25, 2014, 04:46:00 PM »
does anyone know how to replace the headlight?
245luigi
  • Boston, MA
Re: kymco 50 like
« Reply #1 on: April 25, 2014, 06:49:23 PM »
Separate the headset halves and disconnect the speedocable and electric cables, you will then have access to the light
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
big blue
Re: kymco 50 like
« Reply #2 on: April 25, 2014, 07:36:03 PM »
gardeb- Take a look at Stigs post in Like 200i section on Bleeding the Brakes. It shows the handle bar cover removal in detail with great pics ;)
Re: kymco 50 like
« Reply #3 on: April 25, 2014, 10:11:16 PM »
Use my pictures of taking apart the handlebar covers, to get at the back of the headlight. NOTE you do not need to unhook any wires or cables....let things hang gently. Remove the wire to the bulb....and follow the last 4 pictures to replace the bulb.
If it is actually the whole headlight you need to remove- unhook the bulb wire and remove the 4 screws holding in the headlight.
Go here:
http://www.kymcoforum.com/index.php?topic=11272.msg113665#msg113665
