Author Topic: de-restrict???  (Read 1471 times)
england123
de-restrict???
« on: September 11, 2009, 03:58:24 PM »
Iv got the agility 50, 05 plate. when i first got the scooter it was doin around 35mph, then i cut the wire in the cdi and now getting 43mph. but i know other people who are gettin up to 60mph on there agility  ???  :o
how can i get more power?
Re: de-restrict???
« Reply #1 on: September 11, 2009, 04:40:25 PM »
CHeck your variator drive boss...When cutting the cdi, the variator boss should be changed...
..the stock boss has a limiting bushing...
..also check your variator rollers..replace them if significantly worn, or upgrade to a new variator...
..check the condition of your drive belt..if it's worn, replace it!...mine broke at 32,000 km..dont push it that far...
..make sure you have a clean air filter..upgrade to a high flow if you want, but that generally requires re-jetting your carburetor..
..speaking of carbs..check your main jet..should be an 85 if you're derestricted..
..my 08 Agility 50 runs well with the stock air box and an 85 jet...
..these are a few things to get you started...scour this forum for lots of good info and "how tos"...
..WELCOME TO THE FORUM!!
peace
england123
Re: de-restrict???
« Reply #2 on: September 11, 2009, 05:21:08 PM »
cheers
its all stock witch i kno of, its onli the cdi witch iv de-restricted
how can i de-restrict it with outspending any money and that will be simple bcuz iv read some things on the furom but i havent a clue how to do it bcuz i aint that good with bikes lol
& would a racing exhuast give it more speed?
or a 125 carb?
Re: de-restrict???
« Reply #3 on: September 11, 2009, 05:36:24 PM »
..the exhaust upgrade would likely require some carb tuning also...I dunno about the 125 carb...
..variator rollers aren't too expensive, and the benefit is substantial, if the old ones are worn..
..There is a link to the Agility 50 Service Manual in this board somewhere..
..That's a "MUST HAVE" for anyone that plans on doing there own service and upkeep..
..In the famous words of Jprestonian..."TANSTAAFL"
peace
england123
Re: de-restrict???
« Reply #4 on: September 11, 2009, 05:42:51 PM »
ok cheers for the advise
ill just look around on the furom and hopefully have it fully de-rerestriced soon
and do you know how to make the scoot louder?
i got told to drill some holes into the exhuast but i dont know where and how big
Re: de-restrict???
« Reply #5 on: September 11, 2009, 06:06:44 PM »
...dunno about drilling holes...
..good luck with your tuning!!
Shaka
Re: de-restrict???
« Reply #6 on: September 11, 2009, 10:56:29 PM »
England123-  Why do you want to make the scoot louder?  ???  I don't know about drilling holes either, but I'm sure i'd work.  If you upgrade to a high flow air filter and exhaust it should be quite a bit louder.  You could always just cut off the silencer part of the stock exhaust and just run the straight pipe too!
england123
Re: de-restrict???
« Reply #7 on: September 12, 2009, 12:43:09 PM »
Iv got a new air filter and new exhuast on it. makes it extremely louder and abit more power on the take off
