Author Topic: What octane fuel should I use in my X500?  (Read 6271 times)
vespa50sp
Re: What octane fuel should I use in my X500?
« Reply #15 on: May 13, 2013, 11:46:58 AM »
91 non-oxy (no ethanol) whenever I can.
desliderman
« Reply #16 on: May 13, 2013, 01:38:53 PM »
91 octane or better premium every time.  It's hard to find non-ethanol premium here in our area.  I throw a little startron additive in it from time-to-time to help with the reported side effects of ethanol.
feebleknievel
    • Kickin Country hITS
« Reply #17 on: June 18, 2013, 11:14:43 AM »
why not put the BEST IN YOUR TANK...20 cent here and there isn't going to break you for better emission ..CONSUMER ENERGY CENTER...SAYS.... There is little difference in energy content of regular versus premium gasoline. They both contain about 111,400 British Thermal Units of energy per gallon.
The price difference, however, between the fuel grades is anywhere from 20 cents to 40 cents, depending on where you live in the United States. The experts' consensus goes against the long-held belief by thousand of drivers who fill up with premium only, or on every third or fourth trip to the pump. The idea is to fill up with premium every so often to clean out the engines or rev up the performance of older engines.
But according to the experts, this practice is like tossing quarters in a wishing well, since most engines are designed to operate on relatively low-octane regular unleaded gasoline.
Octane is defined as a fuel's resistance to knocking. There is no benefit if the octane is higher than what the engine needs. Engine knock occurs when fuel in a combustion chamber ignites before it should. This disrupts the engine's operation. But electronic knock sensors are now common and have nearly eliminated engine disruption.
The American Petroleum Institute says if you find that your car runs fine on a lower grade, there is no sense switching to premium. The Institute recommends following manufacturer's recommendation, but even those manufacturers say that it is more of a suggestion than a command.
sissy mary
« Reply #18 on: June 18, 2013, 02:37:17 PM »
I use standard pump gas with no pinging or problems.
