Author Topic: kymco agility 50cc -80cc kit  (Read 12715 times)
Re: kymco agility 50cc -80cc kit
« Reply #15 on: April 29, 2014, 09:16:07 PM »
Gy6 50 - 100cc.
They are all the same engine case. and crank  #13000
125 - 150cc
 Different case but share one crank as well.
« Last Edit: April 29, 2014, 09:20:25 PM by zombie »
FlatLander
« Reply #16 on: May 15, 2014, 10:02:00 PM »
Where i can find a hi-speed gear set for my agility?? Every place "has" one, but when i ask if they fit on my Agility then the answer is no.
« Reply #17 on: May 15, 2014, 10:17:14 PM »
What year, and model... I'll find it.
FlatLander
« Reply #18 on: May 17, 2014, 09:15:54 AM »
2007
CK50QT-5 (KG10SA) [KYMCO Agility 50 Basic 4-Takt Typ:CK50QT-5]
« Reply #19 on: May 17, 2014, 10:29:12 PM »
You can get a set from 8% up to 18% reduction.
http://www.racingplanetusa.com/transmission-parts-c-2_122_586-1.html?sessID=7c96cb0ba948059abec8636b0db6fc29
I pick the set you want and google the part # for a better supplier. SPI MAY carry them but I am not sure.
FlatLander
« Reply #20 on: May 19, 2014, 08:28:30 PM »
Those top racing parts would not fit, i've tryied.
« Reply #21 on: May 19, 2014, 11:04:40 PM »
What did not fit/work? In what manner.
They are listed for the Agility.?.?.?
FlatLander
« Reply #22 on: May 20, 2014, 10:08:33 AM »
The shaft that connects to the rear pulley, was too long. And the gears would not eve move when installed.
« Reply #23 on: May 20, 2014, 10:48:09 PM »
I wonder if they are built for a QMB engine... I would call Moped Hospital and ask them. They are a Top Racing dealer.
« Reply #24 on: May 24, 2014, 03:10:15 AM »
Wow that piston is in really really bad shape........
The moped learner
« Reply #25 on: May 24, 2014, 04:04:55 AM »
You said moped😮
« Reply #26 on: May 24, 2014, 07:17:36 AM »
I say alot of other crap too.  ;)
JJJoseph
  • Kymco Sento
« Reply #27 on: May 30, 2014, 05:07:17 AM »
Please clarify . . GY6 50cc . . GY6 150cc
Two totally different engines, each with its own variants.  At this level you should have expert assistance. Do be careful!
