Author Topic: Yoshimura vs. Two Bros exhaust  (Read 2620 times)
Mikethesloan
« on: April 28, 2014, 03:14:51 PM »
Any opinions welcome! What is required of each exhaust in order for optimal performance? Which is louder? Which has a better sound? Which one is easier I install? Is there an exhaust that is better than these two? Edjamacate me!!!!
2013 Kymco Super 8 150 w/ Yoshimura TRC Exhaust
2007 Kymco Xciting 500 - Stock
2017 Kawasaki Vulcan S Cafe
Re: Yoshimura vs. Two Bros exhaust
« Reply #2 on: May 02, 2014, 07:15:18 AM »
You really chose a limited audience with that question. Someone would have to of owned both pipes on the same bike as yours to give an edjumeacieated answer.
Try searching Youtube for the pipes. You may get to hear them yourself.
 One thing I do know is my brothers are both crotch rocket'eers, and out of the last 6 or 7 bikes they have had... Yoshi pipes are the first thing that goes on the bike.
I personally have never seen a Two Bros. pipe
With any pipe you may have to increase your jetting or injector size. Not always but most often. Some times you can get away w/ enriching the idle circuit to compensate
« Reply #3 on: May 02, 2014, 08:14:35 AM »
Mikethesloan
« Reply #4 on: May 02, 2014, 07:57:34 PM »
I ordered the yoshi. The two brothers only makes a slip on. So. It should be here in 2-43 days. Super pumped.
« Reply #5 on: May 02, 2014, 11:40:47 PM »
2-43 days? Did I see that right?
Pumped is the same as Viagra... If it lasts more than 2-43 hours, see your doctor.
Kymco. The forum that cares!
wkreps
« Reply #6 on: August 26, 2014, 02:35:42 AM »
What's the update on this pipe? How's it performing? Speed diff? Sound? etc.
Wayne
« Reply #7 on: August 26, 2014, 03:34:57 AM »
I don't think there is a "slip on" because the header on the super 8 is one piece. I've had yoshi and TBR pipes and have found with the gy6 the two bros sounds better, deeper, and performs better and is lighter.
lukasbasic
  • 2012 Kymco Super 8 150
« Reply #8 on: August 27, 2014, 06:05:46 PM »
I would be interested in the performance boost as well, not sure if I want pay 300USD for an scooter which is now worth probably 1000usd.
