Author Topic: Front diff problems  (Read 1355 times)
eriouel79
Front diff problems
« on: April 29, 2014, 01:35:30 AM »
I just picked up a 2009 UXV 500 and upon inspecting it, I found the the front diff needs new bearings and seals. Problem 1: I can not pull the axle pods from the diff, tried using puller on either side at the same time and pounding on the pods with a hammer and piece of hard wood, then tried using a slide hammer and giving it my all with no success. Problem 2: Can anyone tell me what model arctic cat is the diff out of so i can cross reference parts plz
Macman
Front diff problems
« Reply #1 on: September 16, 2014, 08:08:17 AM »
If you go to Kymcos parts and accessories website you can get the kymco part numbers to order from kymco.  If you want to cross reference, it appears a lot of models use the same differentials and drivetrain as a whole.  Go find a similar year AC 500 I bet it has the same
Drivetrain.  It will be obvious by comparing the parts fiche.
Re: Front diff problems
« Reply #2 on: September 16, 2014, 09:06:14 AM »
2nd on the parts fiche.
Is there a hole in the backing plate or hub? Perhaps it's a bolt in set up.
