Author Topic: Fuel pump repair  (Read 1702 times)
Billyboggs
Fuel pump repair
« on: May 02, 2014, 06:36:42 PM »
Hi all! I'm new to the forum and new to kymco products. I just purchased the uxv500 and am needing to replace the fuel pump. I can't find any info about the fuel pump. Does anyone know how much P.S.I it pumps or if their are any other brands that use the same fuel pump?
Re: Fuel pump repair
« Reply #1 on: May 03, 2014, 01:26:16 AM »
Welcome aboard!
Try Stadium Yamaha for the parts diagram. From there you can google the part number, and it may lead you to what you want. If you just want to order one Call them (stadium) and tell them you are a forum member for 15% off the cost.
I'm SURE your pump is in dozens of engines. Is it a vacuum operated or electric?
Billyboggs
« Reply #2 on: May 03, 2014, 02:01:22 PM »
its a 12 volt electric in line fuel pump.  I would like to be able to just go to a parts store and purchase one that has the same psi and gph
« Reply #3 on: May 03, 2014, 06:58:28 PM »
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=motorcycle%20electrical%20fuel%20pump&_fscr=1
"Motorcycle electric fuel pump" ebay
The only thing you have to know is carb or injected. I have to assume there is a regulator on the machine that controls the pump.
Macman
Fuel pump repair
« Reply #4 on: September 16, 2014, 08:06:15 AM »
I know polaris machines can use automotive style pumps, I can't see how this would be any different or more complicated.  Pull it out and go to the auto parts store.
