Author Topic: Polini Variator  (Read 1077 times)
czechphotoguy
Polini Variator
« on: May 03, 2014, 07:01:51 PM »
So I am ordering parts from SPI but I had a question?
Should I order an upgraded variator upgrade spring also if I get the Polini Variator or does it come with an aftermarket one already that fits?
I'm thinking that I might need to order a spring but just wanted to confirm.
Ross
Re: Polini Variator
« Reply #1 on: May 03, 2014, 07:20:33 PM »
The rear Contra spring is a must have. You want the rear pulley to stay closed as long as possible. This keeps you in a taller gear ratio for better take off, and hill climbing. The Malossi RED has always worked out well fr me. Ask Louie if Polini has a stiffer spring if you start to get into pipes or jug kits.
