Did you miss your
activation email
Technical | How To
2005 Kymco People 50 - Replacement battery
Topic: 2005 Kymco People 50 - Replacement battery (Read 1130 times)
LowellN
Newbie
May 07, 2014, 02:57:30 PM »
Hi Everyone,
I am attempting to buy a new battery for a scooter that I purchased with no battery. The Kymco manual I found online says 12v-6Ah, will the below battery be an appropriate choice? Also will it fit in the compartment?
http://shop.advanceautoparts.com/p/autocraft-power-sport-battery-agm-4l-bs-40-cca-4l-bs/2090287-P?vehicleIdFromReq=-1&isAllVehicle=true&vehicleIdSearch=-1&searchTerm=4l-bs&showTitle=#fragment-2
Thank you all in advance.
You never know do ya!
Close enough to get the idea!
Re: 2005 Kymco People 50 - Replacement battery
May 07, 2014, 09:23:55 PM »
A 6ah is a physically smaller battery. Somewhere on the recent posts here are a few size charts for i think two manufacturers. Try searching for those posts, or the battery manufacturer size charts on line.
Bottom line is I believe NO is the answer to your question.
LowellN
Newbie
May 07, 2014, 09:30:19 PM »
Hi Zombie,
Thank you for your response I assumed the answer would be No, just was hoping I guess.
Doesn't look like Advanced sells then, haha yea trying to use a free $25.00 I have for them before it expires.
Reply #3 on:
May 08, 2014, 12:17:51 AM »
I've been using these...
http://www.amazon.com/Volt-Amp-Hour-Alarm-Battery/dp/B0010XNC06
Three years ago they were 4 bucks. they last as long or longer than wet acid batteries, and I have installed maybe twenty of them over the past four years in every brand 50cc bike you can think of. I have had to replace two so far.
You will have to remove the terminal ends on the factory wire harness, and install these...
http://www.bowessealfast.com/p-2746-terminal-quick-disconnect-14-heat-shrink-yellow-female-12-10-bag-of-25.aspx?gclid=CNj19qSGm74CFU8Q7AodeikAKQ
You can buy a pack of three at Ace Hardware or just about anywhere for a few bucks.
Reply #4 on:
May 08, 2014, 03:07:08 AM »
There are battery dimensions in that link... you can check if it will fit, if it will, then get it....
Reply #5 on:
May 08, 2014, 03:55:35 AM »
LOL!!! I didn't see that
Reply #6 on:
May 08, 2014, 05:35:36 AM »
Quote from: zombie on May 08, 2014, 03:55:35 AM
Get away from that booze!....
Reply #7 on:
May 08, 2014, 06:41:36 AM »
Back
