Author Topic: Bleed oilpump Super 9  (Read 1337 times)
Ice-Tray
« on: May 07, 2014, 03:24:18 PM »
Now I finally got the oil pump and installed it today. But wondering if I bleed the system properly.
Followed the service manual from Kymco.
I fill the oil pump with oil, place on the main hose and start the moped.
It drips out the other side. Should it just drip or shall it flow a lot?
245luigi
  • Boston, MA
Re: Bleed oilpump Super 9
« Reply #1 on: May 07, 2014, 05:35:00 PM »
Driiiiiiiiiiiiiiiip
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
Ice-Tray
« Reply #2 on: May 07, 2014, 06:30:31 PM »
OK, then its all good then.
Ice-Tray
« Reply #3 on: June 25, 2014, 01:17:34 PM »
I'm not sure if the oil pump is properly in order.
When I bled the system so drypte the oil.
But when I'm driving now so decreases almost no oil at all.
How much oil is there it should use normal?
245luigi
  • Boston, MA
« Reply #4 on: June 25, 2014, 01:42:28 PM »
It takes me forever to use the oil in the tank, id say probably 10 or so tanks of fuel before the light comes on.
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
« Reply #5 on: June 25, 2014, 05:12:16 PM »
Think about each stroke of the piston... It uses a MIST of fuel per. That mist will contain between 100:1 or 50:1 fuel/oil ratio.
« Reply #6 on: June 26, 2014, 02:41:21 AM »
Slow drop drop drop out of the hose when run at speed.
Ice-Tray
« Reply #7 on: June 28, 2014, 08:15:09 AM »
Ok, tnx
« Reply #8 on: June 28, 2014, 08:23:23 AM »
I just caught the user name. LOL LOL LOL
