Author Topic: ..carburetor tuning and lessons learned...  (Read 5437 times)
« on: September 15, 2009, 11:22:43 AM »
...carburetor tuning is painstaking, time consuming...
..don't cut corners..learn all you can about what you're going to do, BEFORE you start...
 :o
..PLUG CHOPS will be the key to success!!..
franx93
Re: ..carburetor tuning and lessons learned...
« Reply #1 on: September 15, 2009, 12:23:19 PM »
what are plug chops?
« Reply #2 on: September 15, 2009, 12:42:18 PM »
...the link below is to an awesome carburetor tuning site...
http://justkdx.dirtrider.net/carbtuning.html
« Reply #3 on: September 15, 2009, 01:18:21 PM »
..plug chops are performed when tuning a carburetor..
..their purpose is to give you an indication of what your fuel / air ratio is, at any given throttle position..
..the reason the are so important to perform is, you could be running a "lean" mix..which could do some SERIOUS damage to your engine...
..NEVER RUN LEAN!!
..btw, Tutto..I read one of your posts where you said you had white smoke from your exhaust....
..what I found to be true, is that if you have a "rich" mixture, the smoke will be black...
peace
Shaka
« Reply #4 on: September 15, 2009, 03:25:45 PM »
 :o
I second that! ;D
« Reply #5 on: September 15, 2009, 05:02:38 PM »
Hey guys, I didn't see the white smoke post, but that would usually indicate coolant getting to the combustion chamber.
« Reply #6 on: September 15, 2009, 05:04:24 PM »
..I think Tutto's smoke post was in the K&N thread...
..the Agility 50 is air-cooled...
scoot1234
  • 31 yr. old hudsband and father of 4
« Reply #7 on: September 15, 2009, 05:21:43 PM »
If the smoke is white, I was always taught oil was leaking around the ring burning with the fuel. Black smoke is lean. 8)
I love this forum! It's the best i have found; Very informative, especially because of knowledable peeps.ex.: 'wordslinger', 'shaka', 'Axy' or 'Zombie' just to name four...
« Reply #8 on: September 15, 2009, 06:16:37 PM »
..okay, let's all debate smoke coloring...I was running very rich...I had black smoke from my exhaust...decreased my jet size...the black smoke went away.....
..NEXT!!
 ;D :o
Shaka
« Reply #9 on: September 15, 2009, 08:07:14 PM »
I have a 2-stroke, always blows a little blue smoke.  If it doesn't I have issues! ;D
« Reply #10 on: September 15, 2009, 08:13:29 PM »
..that was always my knowledge..
.. Black = Rich..
....Blue = Oil..2 strokes are a fine example..
..White = Lean..or other issues...
Shaka
« Reply #11 on: September 15, 2009, 09:27:14 PM »
Slinger- I would agree!
scoot1234
« Reply #12 on: September 15, 2009, 10:41:49 PM »
here's a good smoke session:www.tritonclass.org/mir/engsmoke.html www.tritonclass.org/mir/engsmoke.html
source:askjeeves.com
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« Reply #13 on: April 21, 2010, 08:13:21 PM »
I've read in link from wordslinger a thing that I dont understand in my language ... maybe you could say in other way :-s :
"At the end of your full throttle run simultaneously push the kill button, chop the throttle and pull in the clutch."
what kill button ?
he refers at brake ?
Shaka
« Reply #14 on: April 21, 2010, 10:24:28 PM »
I think that is in reference to doing a plug chop.  You want to push the engine shut off switch while maintaining the throttle position until the engine completely shuts off.
