Author Topic: TrailTech Tach AND Temp Sensors  (Read 4661 times)
Re: TrailTech Tach AND Temp Sensors
« Reply #15 on: May 11, 2014, 02:47:28 AM »
Where's the auto correct when you need it. DUCKS. I meant DUCKS.  :-[ :-[
Who said that? I'll trade you for Meth.. omorythious.
wkreps
« Reply #16 on: May 11, 2014, 02:40:18 PM »
How many times I have to tell you . . . NOT ON THE FORUMS. Call my burner phone.
Wayne
« Reply #17 on: May 11, 2014, 07:59:43 PM »
I DID! 4,385 times. SET UP THE VOICEMAIL!!!
wkreps
« Reply #18 on: May 14, 2014, 02:09:11 AM »
For those that have the tach . . . .
1.) What scoot you have (model and cc)?
2.) What kind of numbers you seeing at 1/4, 1/2, 3/4 and WOT?
3.) What are you using the gauge for other than checking idle RPM's?
Wayne
« Reply #19 on: May 14, 2014, 02:16:05 AM »
1; ZX 50
2: 1/4 of full rpm
     1/2 of full rpm
      3/4 of full rpm
      14,500 rpm Thats the only time I look
3: Beer holder/ash tray
I don't see how any of that will help you tho.
wkreps
« Reply #20 on: May 14, 2014, 02:18:46 AM »
1; ZX 50
2: 1/4 of full rpm
     1/2 of full rpm
      3/4 of full rpm
Thanks. Now I need to start saving for a beer holder. Yet another thing I need to buy. And to think I was trying to get this thread back on topic.
Wayne
« Reply #21 on: May 14, 2014, 02:21:35 AM »
Oh! so sorry. You don't really need the beer holder if you switch to forty ounce'ers. Just down one or two before hitting the road.
You do need the ash tray tho. Littering sucks.
Back on topic. Done.
« Reply #22 on: May 14, 2014, 02:37:57 AM »
Temp sensor for the beer... keep 'em cold..
wkreps
« Reply #23 on: May 14, 2014, 10:38:38 PM »
I ordered the Tach, 10mm temp sensor and 4 foot extens cable today. Just need to find a source for rubber grommets to run the wire through the plastic faring. Plan on placing the tach to the left of the cluster and the temp sensor to the right of the cluster.
Wayne
AMAC1680
    • SEGS4VETS
« Reply #24 on: May 15, 2014, 12:29:40 AM »
Mr. Terrilee?
YIKES ! No turtle please no more........
and this is the person held to the "highest regard" by soooo many on some of the "other" scoot forums. I mean this sociopath is a hero to some, go figure.
It's been a while since I even thought of him/her......
At least the billy mummy clip was entertaining !
Be Big,
AMAC
(Sorry for the hijacking)
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
« Reply #25 on: May 15, 2014, 02:45:04 AM »
All the crap in this thread! No one will notice. ;)
Ace Hardware has the grommets
« Reply #26 on: May 15, 2014, 06:31:40 AM »
really?  ;D
wkreps
« Reply #27 on: May 21, 2014, 02:06:36 AM »
Look what came in the mail today/
Wayne
« Reply #28 on: May 21, 2014, 01:16:06 PM »
I know you've spent your hard earned $$ on these things - but maybe consider using some of that Red 3M 2-sided rubber tape to install the gauges....at least for a time. Until you are sure you have found the right position for them...or that you even want to keep them -before cutting or drilling into the plastic head-set. I've had my TTO tach placed on my scoot for nearly a year with the 3M stuff. It has not moved, but I could remove it with no damage if I wanted to.
wkreps
« Reply #29 on: May 21, 2014, 03:07:14 PM »
That's what I was going to do (use the sticky tape). Mount one on each side of the cluster and run the wire straight up and make a small U shaped cut where the black and colored plastic meet and use a grommet to run the wire through. I could run the wire to the side and avoid harming the plastic at all but I was slightly worried about vibration on the wire over time and causing a short issue. That's why I wanted to use the rubber grommet between the two pieces of plastic. Am I overthinking it? Plus I didn't want it to look "jerryrigged" together.
Wayne
