Author Topic: Simple question/Roller Weights  (Read 5108 times)
Re: Simple question/Roller Weights
« Reply #15 on: May 20, 2014, 10:50:45 PM »
Right now the engine is 100cc (50mm kit) so the belt wear is to be expected. All the replacement belts I've tried are also shorter than the OEM Bando, and drop a few MPH.
I like the MPH gain, and for 40 bucks it's worth it to me.
« Reply #16 on: May 22, 2014, 02:45:29 AM »
I tryed other belts but always found the bado belts work better for me.
The moped learner
« Reply #17 on: May 22, 2014, 02:20:00 PM »
I still have the same belt that came from factory and it just clocked in over 6,300 miles
MoToFaLcon
  • I Fly....
« Reply #18 on: May 22, 2014, 09:11:39 PM »
Blue, bado belts? ;) But yea guys thanks for all the info, greatly appreciated. Ill probaby check the belt around 4 or 5k and buy a bando for backup. Thanks again ;D
« Last Edit: May 22, 2014, 10:02:28 PM by MoToFaLcon »
WTF, i have a Ninja 650!!
« Reply #19 on: May 22, 2014, 10:57:20 PM »
[/quote
Order a new one, and keep the old one for an emergency spare.
Thank me later!!
« Reply #20 on: May 24, 2014, 02:24:29 AM »
I tyed gates but I brake them to fast so I have been sticking with bando belts.
« Reply #21 on: May 24, 2014, 03:03:08 AM »
I see the stock roller weights go bad anywhere from 5000km-10000km depending on rider weight, and mostly how you drive the scooter. A lot of high RPM high speed driving will flat-spot the rollers faster than city driving. About your CVT maxing out at 28mph, ask your dealer about de-restriction. It sounds like they did not install the de-restricted boss hence making your variator max out at 30. On a happy A50 I the variator starts to hit high gear at about 35mph and top speed 38-40 indicated and im 200lbs. Make sure that if you Kymco dealer does install the de-restricted boss that they also up-jet the carb so the bike is not running lean at high rpms. One comment about the Agility City 16" we can't get these in the US because Kymco USA won't import them for some reason, if you are lucky enough to have a friend in Taiwan you could send them cash, pay to have it shipped ($$$$$$$) and if you get lucky enough your DMV will let you title it. I've been at a Kymco dealership for over 5 years and still to this day do not understand who is in charge of choosing what bikes get imported to the US. I sometimes browse the Kymco global site but it only makes me sad to see how many awesome scooters and small motorcycles we are missing out on here.
MoToFaLcon
  • I Fly....
« Reply #22 on: May 24, 2014, 07:12:22 AM »
.........right on. Bado my faverought nows.
« Reply #23 on: May 24, 2014, 07:14:51 AM »
I've had good luck with Gates belts but my complaint is they are NEVER the same size as OEM.
« Reply #24 on: May 24, 2014, 07:18:54 AM »
Same here. I used them for quite awhile but they are shorter/slower.
« Reply #25 on: May 24, 2014, 07:21:10 AM »
Its funny for the people 50 service limit say 17mm and I've gotten gates belts NEW at like 17.2 lol.
MoToFaLcon
  • I Fly....
« Reply #26 on: May 24, 2014, 07:23:11 AM »
BettinANDlosing: Great answer above, thanks. As for the 28mph max, my a50 max is actually about 34mph. Dealer did the jet upgrade and something in the cvt for like $45 extra. I was just saying my cvt sounds funny around 28mph, has a rattle, either that or its my center stand? Or both?
« Reply #27 on: May 24, 2014, 07:25:27 AM »
34 is pretty good all stock. Maybe they didn't install everything correctly. Did you hear the rattle from day 1, or after they de-restricted your scoot?
MoToFaLcon
  • I Fly....
« Reply #28 on: May 24, 2014, 07:32:03 AM »
They de-restricted it on day one before i even rode it for the 1st time. I didnt notice the rattle until i was around 400km maybe. But when i hear the rattle, i push down on the center stand and it goes away about 75%.
« Reply #29 on: May 24, 2014, 07:35:07 AM »
The center stand has two quarter sized rubber bushings see it they are in good shape, sometimes they fall off.
