Author Topic: cops keep eyeing my exhaust  (Read 5457 times)
kimura
  • 2012 super 8 50cc 2t
« on: May 12, 2014, 03:18:55 AM »
2012 kymco super 8 50cc  stock exhaust. I've noticed twice in a weeks time that the first thing cops look at when they see me coming is my exhaust.  it's currently a stock exhaust but Ive been planning to upgrade to a performance exhaust with an expansion chamber, but now I'm not so sure that might be a good idea. I live in the NY area, are cops in this area known to be any more strict?
Re: cops keep eyeing my exhaust
« Reply #1 on: May 12, 2014, 03:28:08 AM »
NY Cops!!!!! Haven't you heard of the Blue Taxi?  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Give them five bucks, and a bag of joints. They will LOVE you.  Tell em' Zombie says yo!
Chris0381
« Reply #2 on: May 12, 2014, 12:44:00 PM »
Are you sure your not stashing weed in your exhaust and its burning while your driving. Do you have a van full of hippies and a peace sign on it following you around ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
kimura
« Reply #3 on: May 12, 2014, 05:57:48 PM »
no weed here guys.
Today i noticed another screw was missing, maybe thats what been drawing their attention. lol
you guys weren't kidding when you said to go around the bike and make sure I tighten everything. this is the 2nd screw that has fallen out. :\
its the bottom left in this pic
DMblues01
  • 2012 Kymco Super 8 150
« Reply #4 on: May 12, 2014, 06:08:17 PM »
Spend a few cents on some lock washers. Should help with those heat shield bolts.
Roxana, IL
Yoda is my spiritual leader.
Chris0381
« Reply #5 on: May 12, 2014, 06:11:26 PM »
no weed here guys.
Thanks for providing that experience, Im just at 2000 and I'll make to check what screws and bolts I can reach.
On the serious side, does your exhaust sound loud and have talked to you about your bike ?
Smooth Boss
Polini Variator
#95 Main Jet
kimura
« Reply #6 on: May 12, 2014, 06:13:34 PM »
thanks bro, do you know what size I should get?
DMblues01
« Reply #7 on: May 12, 2014, 06:23:52 PM »
Just take the bolt to the hardware store and find the ones that have the right size hole. Pretty simple, and a really cheap fix!
Roxana, IL
kimura
« Reply #8 on: May 12, 2014, 07:04:32 PM »
its not loud, no one has stopped me yet, it seems they are just on the look out for modded scoots. maybe getting the lower profile traffic exhaust might be a better idea. I don't know.    ???
DMblues01
« Reply #9 on: May 12, 2014, 07:09:22 PM »
I think it's just the way the super8 exhaust is designed. I've had several people ask if the exhaust on my 150 is aftermarket. They seem surprised that it's stock, until they notice the tiny pipe coming out the back.
Roxana, IL
bluesin
  • 2012 DT 300i
« Reply #10 on: May 12, 2014, 07:53:13 PM »
You can buy scented additives for fuel in bikes. One is cannabis scent. I think Zombie designed it . :o
« Reply #11 on: May 12, 2014, 11:49:40 PM »
No. But I will be buying every ounce of it I can find!
kimura
« Reply #12 on: May 13, 2014, 03:22:37 PM »
since someone mentioned the tendency of the bolts of the exhaust shield coming loose, I've been checking them every day. I made sure not to over tighten any of them but this one just turns in endlessly without any tightness.  will the lock washers help in this case?
this is the bolt that does not tighten.
« Last Edit: May 13, 2014, 03:25:45 PM by kimura »
DMblues01
« Reply #13 on: May 13, 2014, 03:30:35 PM »
If it won't tighten, then you may want to check to see if it got stripped out somehow. If the threads are stripped, then the lock washer won't help a bit. It will need drilled out, and new threads cut for a different bolt.
If you're lucky, the threads on the bolt itself could be stripped. If so, you just need a new bolt, and run a thread tap through the hole to clean it up.
Roxana, IL
kimura
« Reply #14 on: May 13, 2014, 03:51:38 PM »
thanks for your help.
I dont understand how it could have been stripped? I just got it, it only has 400miles on it, as far as I know, that bolt has only been touched once when the bike was put together.
