Author Topic: Remove the bolt from the exhaust ?  (Read 1165 times)
Chris0381
« on: May 12, 2014, 01:18:04 PM »
On the back of the exhaust there is a shiny bolt. I read thru the threads that some people remove is as part of a minor derestriction. A lot of the threads though on the forum just end with no one posting back the results or conclusions and kinda leave the thread hanging.
So may I ask if its good to remove that bolt as part of the derestriction?
TY
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Super8:50:2T:2013
Re: Remove the bolt from the exhaust ?
« Reply #1 on: May 14, 2014, 12:08:12 AM »
Hello Chris,
I believe I read that the bolt is a location that the tech's use to connect diagnostic equipment to at the dealership.
Good luck !
« Reply #2 on: May 14, 2014, 12:51:47 AM »
It wont de-restrict anything. It will make it sound like a plastic Big Wheel heading down hill tho.
I've drilled six 3/8" holes around the back plate, and ground off the tiny outlet tube on 1/2 dozen bikes, and that sounds pretty cool. No performance upgrade tho.
Chris0381
« Reply #3 on: May 14, 2014, 11:26:11 AM »
Thanks Zombie I should have removed the thread. Im seeing in another post that its used for emission testing.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #4 on: May 15, 2014, 03:05:43 AM »
No issue... Now we have a thread to play on. Thakns!
