No it is not needed. Take off the stainless pipe, and sandwich a piece of soda can to block off the port on the cylinder head. Then use the rubber hose that went to the egr, and mount it on top of the valve cover as a breather.
OR you can re-use your cylinder head, and keep it all as is. The bore kits work better with the OEM small valve/small combustion chamber anyway.
