Author Topic: Do I need this on my SCOOTER😉?  (Read 4504 times)
MoToFaLcon
  • I Fly....
Re: Do I need this on my SCOOTER😉?
« Reply #30 on: May 20, 2014, 05:08:05 AM »
Youtube is my friend too. Starting this week, its learn time baby!!  Finally got some free time! Coffee and youtube  ???
WTF, i have a Ninja 650!!
The moped learner
« Reply #31 on: May 20, 2014, 02:07:12 PM »
Ohh the oil pump works if i turn the engine on with the valve cover off it will flow like a cut water line
The moped learner
« Reply #32 on: May 20, 2014, 09:47:02 PM »
All done the kit is on i need to upgrade my jet a bit because it runs a little hot and it stalls out at 7600 rpm at times
« Reply #33 on: May 20, 2014, 10:09:28 PM »
You already F'd it up.  You need at least 100 miles at less than 1/2 throttle to seat the rings, and wear in the bore.
I would enrich the Idle circuit to compensate for the main (which you will not be needing) change the oil (again), and give it the 100 miles before beating it.
The moped learner
« Reply #34 on: May 20, 2014, 10:57:49 PM »
Idle circuit? You mean Idle jet
« Reply #35 on: May 20, 2014, 10:59:57 PM »
Yes. Adjust the Idle mix screw to enrich the low end rpm. This will help cool the cylinder until you get a proper main jet.
The moped learner
« Reply #36 on: May 21, 2014, 03:08:29 AM »
How I do that all i have for a sort of screw is a weird shaped knob
« Reply #37 on: May 21, 2014, 04:54:04 AM »
You do have a fuel mix screw. It's near the intake manifold.
